Hi, i have an R34 gtt and occasionally my engine check light comes on for no apparent reason, the oil is new, the plugs are good, the coil packs are a bit average and its probably due soon for a timing belt but other than that there isnt any problems, the light has only just started to come on and stays on for a minute or so then goes off again..
Any ideas???
Thanks for your time..
https://www.sau.com.au/forums/topic/362152-engine-check-light/
There are too many things which can trigger the warning light. Get a nissan consult cable and read the errors from the computer. The check engine light is not designed to tell you whats wrong(you can use it for diagnosis but that's a different story), its designed to tell you SOMETHING is wrong. You can't do anything without a consult cable.
http://cgi.ebay.com....=item231027be4a for example. Pretty sure all consult ports are the same...
^ Is that true for the R33 series 2? One of my coils just died and no check engine and I was clearly running on 5 cylinders.
Edited by SargeRX8
nah, as far as i know it's only the r34
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
