FS: GLOWSHIFT Water temp Gauge 7 colour 52mm
Item Description: Glowshift Water temp gauge. Black face.
Item Condition: Great (includes everything all boxed. Sensor too)
Reason for selling: Upgraded all gauges.
Price and Price Conditions: $40ono (will send AUS wide)
I've upgraded the gauges in the car to match. Just trying to offload my old.
I've attached a picture of what it looks like. Also some more info. from there site.
Does come with gauge temp sensor.
Gauge Series Features:
Black face gauge with magnified tinted lens
• Black trim ring with black housing
• Red illuminated needle with full sweep
• Electronic Gauges has Opening Sweep Movement
• 7 color LED illumination number glow and color recall technology
(Gauge will return to previous color when vehicle is turned off)
• Fast and slow automatic color changing modes
• Gauge visor
• Mounting and Installation hardware
• Instructions
• 2 1/16th inch gauge or 52 mm diameter
Water Temperature Gauge Includes:
• All mounting hardware (including sensor)
• Gauge Visor
• Detailed installation instructions
• Reads: 40 to 150 C
• Electrical Gauge
• Free Tech Support
• 12 month limited warranty
GlowShift's Tinted 7 Color Celsius Water Temperature Gauge offers a unique combination of a high performance features including multiple backlit colors, a black face with a tinted lens and color recall technology while still offering an affordable price. This model reads the engine's coolant temperature between 40 and 150 degrees Celsius, by using an included electrical temperature sending unit. Each tinted faced gauge sports a red illuminated needle with a full 270 degree sweep of the entire gauge allowing maximum accuracy. GlowShift's ground breaking seven color LED technology allows the user to select a color of their choice to be displayed at anytime, as well as the choice of fast or slow color changing modes. The color recall technology allows the gauge to remember the previous color selected after the gauge has been powered back up. All Tinted 7 color Water Temperature gauges come complete with a 1/8th npt male thread electrical water temperature sender and full installation instructions. All products include a one year warranty and free technical support with each gauge.
FS: GLOWSHIFT Air/Fuel Gauge 7 colour 52mm
Item Description: Glowshift Air/Fuel gauge. Black face.
Item Condition: Great (includes everything all boxed.)
Info. from there site.
• Gauge visor
• Instructions
Air / Fuel Ratio Gauge Includes:
• Gauge Visor
• Reads: Lean to Rich
• Electrical Gauge
• Free Tech Support
GlowShift's Tinted 7 Color Air/ Fuel Gauge offers a unique combination of a high performance features including multiple backlit colors, a black face with a tinted lens and color recall technology, while still offering an affordable price. This model reads Lean, Optimal, and Rich values from the o2 sensor. This narrow band gauge is perfect to monitor your Air/ Fuel Ratio at any time. Each tinted faced gauge sport a red illuminated needle with a full 270 degree sweep of the entire gauge allowing maximum accuracy. GlowShift's ground breaking seven color LED technology allows the user to select a color of their choice to be displayed at anytime, as well as the choice of fast or slow color changing modes. The color recall technology allows the gauge to remember the previous color selected after the gauge has been powered back up. All Tinted 7 color Air/ Fuel gauges come complete with full installation instructions, along with GlowShift's one year warranty and free technical support.
  • 3 weeks later...
  • 1 month later...
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
