Hey,
Building my track 180sx from home, and just trying to get some ideas of how I can brace the car up, make harness bars, and even things like custom switch panels, alloy dashes, transmission tunnel covers. Basically post what you have made or seen, pics of fabrication in interiors and how you did it. Just chasing ideas!!
I will post pics soon of how I will modify my R32 GTS-T rollcage to suit 180sx... if it needs any mods! And dont flame me, I am 1000km north Brisbane and its not easy to sell large items due to shipping, and I have a r32 cage at home I dont need so...
cheers :)
https://www.sau.com.au/forums/topic/362423-interior-fabrication/
youll have to change your sig btw Leon haha
Are you going to do a custom dash with aftermarket gauges + switches? These look pretty good if done right. You dont have the original dash so I Guess youd have to go to scratch. I like the custom ones where they basically cut the middle section out of the centre dash and put a flat plate there and put switches etc on it then a similar thing for the dash. Simple way to do it is just a flat plate across the front with gauges and everything in it I guess. Interested to see how it turns out
Not very helpful but anyway lol
Edited by 89CAL
I took the s13 dash to the dump, it was cracked, and looked shitty. I was searching ebay today and found one in worse condition for $80, what a rip!!! I dont know what I'm gonna do. Havent ever seen a full alloy dash in a s13 like barts Feroza had. I will probably go with a Racepak dash, as buying guages to suit the LS motor for speedo, rpm, water temp, oil temp, oil pressure, etc will cost a fortune. Gotta find out if Racepak is compatible though.
My current interior, pretty bare
This is what I was talking about:
But if you dont have a dash.....
Maybe something like this..... (I know its in an AE86 and appears to be using a modified standard dash, but its simple enough to make up)
Edited by 89CAL
Yeah, I thought about doing something like the top one, and if I can find a good condition S13 dash for reasonable price I will. Otherwise it will have to be custom. I do have a sheet metal bender that does up to 800mm wide, so should be able to do it myself, along with the tig to weld brackets onto it.
I have seen that done once before.. but its alot of money for a track car. I tried to fit an R32 dash of mine, and it needed alot cut out and didnt line up with the windscreen very well, so i scrapped that idea. Budget alloy dash is probably gonna be the go, unless someone in Mackay crashes their S13 with a mint dash haha
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
