All items from an R32 GT-R. Cash only, no swaps.
RB26 Head with stock cams. $1200
RB26 Covers, Cam Covers/Coil Pack Cover and Timing Belt Cover, plus -10 Breather fittings. $400
RB26 Timing Belt Cover (Spare). $100
RB26 Inlet Manifold & Throttles (pulled apart currently). $250
RB26 Stock Turbos/Exhaust Manifolds/Dumps. $450
RB26 Injectors/Rail + Resistor Pack. $400
RB26 Harmonic Balancer. $100
RB26 Alternator. $80
RB26 Starter Motor. $80
RB26 Power Steering Pump. $80
RB26 Pistons/Rods. $180
RB26 Engine Loom/Mines ECU + AFM's. $400
Also available RB30e complete with Auto, ECU.
Please pm or call me for more information. Scott 0 418 57 9423
https://www.sau.com.au/forums/topic/362609-fs-rb26-head-and-other-engine-parts/
