Hi all,
I am selling of my new set of Genuine HKS Stainless Exhaust Manifolds to suit R32/R33/R34 GTR
HKS Exhaust Manifolds are absolutely top shelf items and the best Japanese aftermarket exhaust manifolds you can buy - These are brand new in the box and have only been opened up for the purpose of taking a photo.
Part Number: 1419-RN001
Retail on these from Nengun is ~$1800.00 + Shipping and Tax so well over $2000.00 to replace.
http://www.nengun.com/hks/exhaust-manifold-stainless
I have inadvertently ended up with two sets as I got impatient and picked up another set in Sydney while I waited for these to come from Japan so I need these gone quickly to recoup some costs.
In the interests of a quick sale I am asking $1300.00 - Yes, you read correctly, that is a $700.00 saving on buying them yourself from Nengun!!
No low ballers, no time wasters - First in best dressed.
Located in Sydney, pickup available and happy to post if needed.
Thanks.
these look like a nice bit of gear, do you no if people have probs with these cracking like the Tomei ones? also how they fit up? can you still run the same oil and water lines as factory? turbos sit in the same position?
very interested
very interested
They sit in the factory position and are direct fit replacements for the factory manifolds so the fit is perfect.
They are extremely well made and if anything are better quality than the tomeis so provided your tune is correct and your EGT's arent through the roof like some cars using E85 for example, you will be fine.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
