Here's where i'm at.
i have a coolant leak from one or both of the hoses under the intake manifold towards the back of the engine (nearer the driver). i want to take the intake manifold off and replace every hose and clamp underneath it and fill it with genuine nissan coolant to avoid any leaks or corrosion (nescessary???)
all nuts are off the maniifold and fuel lines under the manifold are still fixed to the manifold but the hoses either end are pulled off.
i've pulled the hoses to the brake and clutch boosters off so it's just the two steel pipes stickking up through the manifold at the moment.
my questions, is it easier to remove the hoses from the underside of the intake manifold and unbolt the iac valve housing to free up the manifold?
or leave all iac valve components attatched to the manifold and remove the intake manifold with the iac valve still attatched? is that possible?
anyone with experience removing the rb26 intake manifold, i need help! any info would be great on this removal. i'm pretty close as it is but the manifold isn't free yet.
cheers
https://www.sau.com.au/forums/topic/362850-r32-gt-r-intake-manifold-removal/
you have to remove the iac valve its only 4 bolts and easy to access
thanks heaps. i'll have a look tomorrow as i'm on annual leave at the moment. it's my daily driver so i have to do it before i go back to work on the 9th i think it is...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
