1992 Nissan R32 Skyline GTST
2.0L turbo
Black
109,000kms
REG till end FEB2012
Exterior
Full GTR body kit
350z anniversary wheels
Khumo KU19 front and KU31rear excellent thread
Projector headlights with Xenon Globes
Engine
R34 GTT OP6 turbo
HKS adjustable actuator set to 12psi
3" Dump pipe
3" Front pipe with flex
3" cat back exhaust to oval muffler
Yellow Jacket coilpacks
ARC intake (counts as OEM replacement)
GREDDY front mount intercooler
Koyo Aluminium Race Radiator
GTR strut brace
Optima Yellow Top D34 battery
100,000kms completed at Japwarehouse
Gates Racing Belt
All belts and pulleys replaced
new water pump and seals
Excedy HD Clutch
Interior
GTR front seats
HKS half cage with side intrusion
Drift digitial boost guage (red)
Illuminated Dash (red)
Pioneer HU with USB ipod connection
Steering and Suspension
Greddy type S coilovers, base height adjustable 8kg and 6kg spring rates
Greddy electronic damping system (EDFC)
Solid Subframe bushes
This car used to be an ex show car for an audio company. Hence the fresh respray and body kit + vented bonnet.
Serviced every 5000km with Motul 4100 turbolight
RWC will need new indicator stalk (push to high beam does not work, pull works)
Requires roof respray, tree branch fell on it, quoted $400 @ DT.
$10,000
Negotiable minus parts (as a guide)
Standard radiator -200
standard suspension -1000
standard coils -200
replace arc intake for pod -250
standard battery -200
no headunit -200
BYO wheels -800
no cage -500
result is a clean stock car for $6650
with basic mods: r34 turbo, 3" dump, front and rear and a pod.
Car has a clean record with police, followed and let go every time.
Standard issue registration plates will be provided with sale.
"HAYAKU" plates available for $2000
Ron: 0401177295
https://www.sau.com.au/forums/topic/362945-r32-perfect-street-car-10000/
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
