Hi all,
I'm selling my 1989 R32 GTR which i have owned for a little over a year. It was previously owned by 'YAWN' (Melbourne). It has spent 90% of the time i have owned it in the shop with the engine stripped back and re made to what is listed below and what you see in the pictures. All engine gear is brand new with top quality parts.
I'm selling it due to other commitments including the purchase of a new car & boat - I'm not interested in swaping for anything, thanks.
As i dont care much for computers, i dont own one, so i'm writing this with the help from a mate.
125,000 Km’s on the clock – less than 5,000 on the new motor
All engine gear is brand new!!
· Tomei 2.8L Kit
· New R34 N1 Crank
· Tomei Pistons & Rods
· Jun oil pump (Billet)
· 9L extended sump
· ACL race serves main + big end bearings
· BAL rotating assembly
· Studs through out / ARP rod bolt
· Tomei pro cams
· Heavy duty springs (Valve)
· Ported head
· Adjustable cam gears
· Garret T042 Roller turbo
· Turbosmart 50mm gate (screamer)
· Exhaust manifold
· 3 Inch exhaust – Jazima
· Blitz BOV
· Exedy twin plate clutch / billet flywheel combo
· Dog box
· Apexi Power FC / Detro conversion
· Ray’s wheels
· Ohlins coilovers
· Brembo brakes
· Slotted rotters
· Dephi Gauges
· Momo steering wheel
· Nismo dash
· 4 Point harness
· Sony head unit
  • Bride bucket seat
  • Oil Catch can
  • Carbon Fibre hood
  • Front mount intercooler
There is probably a few more things not listed that i cant remember.
Car makes 400 KW ATW on 20 PSI – 98 Ron Fuel
Looking for $33,000 ONO
Car located on the north shore in Sydney.
Best to call to discuss.
Call me to come organise a time to come see the car -Damon 0406 819 511
Thanks.
post-65218-0-65662300-1304654530_thumb.jpgpost-65218-0-46415100-1304655270_thumb.jpgpost-65218-0-62442200-1304655276_thumb.jpgpost-65218-0-68495700-1304655286_thumb.jpgpost-65218-0-02039300-1304655292_thumb.jpgpost-65218-0-91007400-1304655300_thumb.jpgpost-65218-0-34868300-1304655307_thumb.jpgpost-65218-0-92617900-1304655313_thumb.jpgpost-65218-0-01307200-1304655320_thumb.jpgpost-65218-0-69830500-1304655326_thumb.jpgpost-65218-0-12556600-1304655333_thumb.jpgpost-65218-0-24236300-1304655341_thumb.jpg
https://www.sau.com.au/forums/topic/363317-1989-r32-gtr-400kw-atw/
Get Set:
2 oil pumps (N1) blew as they couldn't handle the power & the bearings seized to the crank, therfore the crank was replaced to the R34.
Dog box - straight cut gear set - syncro
Cams - Pro Cams.
If you want full specifications , You will have to give Tomei a call to retrieve off them as i dont have them.
Tony @ Boostech in Five Dock built and tuned the car.
Cheers!
Oh Dear Arab Skidder, "im confused on how does a r34 crank fit in a block now honned to 2.8ltrs?" Does anyone want to explain to this serial pest how wrong his comment is and why it makes him look like a uneducated twat? Hey AB, leave this thread alone, I think we can all make up our own minds about it.
:pirate:
update:
1000cc injectors - i believe they are siemans
Walbro internal pump - no surge tank
Unaware of the brand gear set sorry.
Car needs to go.
I will be putting it on carsales hopefully tomorrow to get it sold.
Thanks.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
