Driving along, went to change into second, pushed clutch in and heard a loudish crack... then discovered the clutch wasn't disengaged. I'm guessing it's likely the master cylinder has shit itself as the same thing happened to the VL once, though it could the pivot point or something I've heard is apparently "weak" with these gearboxes...
Thoughts? Had to cruise over to aunt's place with only 2nd gear zzzz
https://www.sau.com.au/forums/topic/363393-so-i-just-lost-my-clutch/
Well car is IN Kambah at the moment out the front of my aunt's place, their neighbour runs a mechanic business from his backyard. Might get him to sort it since it's there lol. I'm really hoping it's the master cylinder like the VL :(
It's not losing fluid that I noticed, but it can still be the master cylinder. With the VL I used to drive, the exact same thing happened (though I didn't hear/feel the snapping of whatever broke) while changing from 4th to 5th on the highway. The pedal would have no resistance until just before the floor, which wasn't enough to disengage the clutch. Turned out there is a spring inside the master cylinder that had snapped into 3 pieces, and however the master cylinder worked it was required to allow it to pump fluid through to the slave. Something has snapped, so I'm thinking it's either the same deal with something inside the master cylinder, or the fork pivot has snapped. Will find out soon enough, at least the car is right next door to a backyard mechanic who'll apparently do mates rates for me...just gotta find the culprit then get him to replace it :)
The dude next door to my Aunt's place will have a look at it over the next few days. He runs a business called "Pal's Automotive" or something similar, so at least he's got a hoist etc :P
He'll let me know what's broken then I'll go from there I suppose, though I did get my aunt to pump the clutch while I had my head on the ground watching the slave cylinder - it moves, just not nearly as much as I think it should. Good sign in a way I suppose
rofl, not THAT clutch >.>
yeah Jono that was the first thing I looked at, unfortunately that ain't the problem. It's been suggested part of the whole bracket that the pedal is held in place by has snapped....I dunno, haven't heard anything from the mechanic dude yet, though I told him no rush. I'm not too fussed about riding everywhere on a pushy lol
Pedal box broke. Need new pedal box. FML.
Although somehow bleeding the system plus removing an apparently unneeded reservoir near the slave cylinder has given me use of my clutch again.....anyone explain???
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
