Hey all I got a 3.5 hks super dragger exhaust its a cat back from a r33 coupe but will also fit on a 33 sedan. Has no dents only slight scratches under the middle muffler as it scraped few times cause my car being too low but other then that it in perfect working order, good exhaust if u want power without bein too loud
looking for 350 plus postage
Pm or msge 0404391948
located in Townsville pics available on request
https://www.sau.com.au/forums/topic/363642-35inc-exhaust-for-sale/
  • 1 month later...
  • 1 month later...
had potenial buyer for exhaust but fell through so still for sale.
Also got a standard r33 turbo done approx 70 000kms excellent working condition never been boosted for $200ono
And a full standard r33 exhaust for a 4 door from the dump pipe im not sure if it will fit a 2 door it might with modifications to it for $180
or i can do both turbo and exhaust for $350
number is 0404 391 948
  • 4 weeks later...
  • 4 weeks later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
