hi have a 33 ive had for awhile
things have changed so need to get rid of it
all interior parts
front seats - $150
rear seats - $100
seat belts - $50 each
rear shelf - $30
carpet - $100
dash facia - $40
glove box - $30
centre console - $50
door cards - $40 each
rear plastics - $20 each
a / b / c pillar plastics - $10 each
hood lining - $80
exterior parts
boot - $100
series 1 wing - $50
series 2 wing - $50
m spec side skirts - $100
400r rear pods - $100
tail lights - $50 each
passenger side door
all glass
drivers side gaurd - $100
dash loom - $100
r33 front strut brace - $100
front brakes - $300 with rotors
rear brakes - $200
wipers
fuel tank - $100
brake lines
fuel lines etc etc
engine bay items
rb25det injectors - $80 or $100 on rail
rb25det CAS - $70
rb25 starter - $60
rb25 alternator - $60
rb25 inlet plenum - $100
rb25 turbo manifold - $50
rb25 series 2 engine loom - $150
rb25det 5 speed ecu - $100
rb25 engine cross member - $100
r33 power steering resevior - $40
r33 steering rack - $100
r33 engine fuse box - $40
rb25det series 1 coil packs - $80
rb25det series 2 coil packs - $100
rb25det series 1 coil pack loom no broken clips :) and ignighter - $60
rb25det series 2 coil pack loom no broken clips - $30
rb25det stock cams - $50
WILL ALSO DO THE SHELL AS FRONT OR REAR OR PANEL CUTS ETC ETC
PROBLY OTHER THINGS IVE FORGOTTEN
HIT ME UP FOR ANYTHING UR LOOKING FOR
CAN ALSO TEXT ME ON 0435494669
HAPPY TO MAIL SMALLER ITEMS
IM LOCATED NORTHERN NSW NEAR BYRON BAY
CAN DELIVER ITEMS AS FAR UP AS BRISSY IF WANTED
THANKS
Edited by team carefactor
https://www.sau.com.au/forums/topic/364032-wrecking-r33/
  • Replies 69
hi everyone
yeah i do have series 1 inner gaurds
no drivers side window switch
no manual gear surround
yes i do have AFM
and yes do have both washer bottle motors
thanks
https://www.sau.com.au/forums/topic/364032-wrecking-r33/#findComment-5813468
hi everyone
yes i do have AFM
thanks
Price?
https://www.sau.com.au/forums/topic/364032-wrecking-r33/#findComment-5813536
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
