For sale... Fiberglass front diffuser to suit R32 GTR (brand new)
This diffuser will improve airflow under your car to increase front down force, while also channeling air to your front brakes.
This will also fit a GTSt, but if you're running a standard front bar you will need to modify the attachment hardware to raise the height, to match the bar.
I've been running one of these on my car for the last couple of years, but recently had to change the front bar due to an incident with a Wallaby. I bought a second diffuser as I thought I'd have to modify the attachment points to suit the new bar, but as it turns out I didn't need to use it.
So I'm just trying to get back what I paid for it.
$250 + $25 postage Australia wide
Local pickup is available from Nowra, NSW.
https://www.sau.com.au/forums/topic/364256-r32-front-diffuser-brand-new/
im keen but what a pain to change the oil
There's a little window that is held on by two scews to access the oil drain plug. If you look carefully at the first photo, and you'll see it.
I haven't found changing the oil to be a hassle.
Have you got a photo of it from the front?
+1 to this.
Does it replace the N1 Brake vents? A pic from the front should clear up any questions that i have! Cheers :)
Here's a couple of photo's of my car from the front.
Please note though that my front bar in an aftermarket fibreglass one, and not a standard GTR bar. The front of the diffuser is hiding underneath the splitter extension I glassed onto the bar.
Are these designed for the standard N1 front bar? Will it sit flush with the N1 Lip or what?
Yes it is designed for the standard R32 N1 front bar (see the 2nd photo, in the first post)
I can't see why it wouldn't sit flush with the N1 Lip, though I haven't personally fitted one to the N1 bar.
With a little modification to the attachment points you can modify this to suit almost any R32 front bar, as I've modded mine to fit two very different bars on my car.
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
