Guest INASNT
145 db from the exhaust??
Bullshit!!!
Do you have any idea what 145 db sounds like?
Car stereos that are almost gut wrenching make about 130db..
Yes it alot of bullshit.
145db is more sound than a space shuttle makes when taking off from houston.
If this 180sx made 145db, everytime it drove down the street it would blow all the windows out at all the houses it drove past.
https://www.sau.com.au/forums/topic/36468-what-rwkw/page/2/#findComment-731286
didn't know turbo cars could be that loud saw the bandag bullit on the weekend and that has 4 turbos the size of T88's and it ran 110 psi with about 7" dumps no wastegate no exhaust with flames pouring from dumps and that think was quieter than just about all the cars there
https://www.sau.com.au/forums/topic/36468-what-rwkw/page/2/#findComment-731298
