Hey guys, I was going through some pictures of a car and noticed these weird grey patches on the underbody, does anyone know what they might be? At first I thought it was rust repair but there's way too much of it for it to be cut out, repaired and welded... I mean it could be. What do you guys think? Here are some pictures:
http://imageshack.us/m/580/2233/203tz.jpg
http://imageshack.us/m/30/7345/204yv.jpg
http://imageshack.us/m/864/6320/191b.jpg
http://imageshack.us/m/822/3536/189kz.jpg
http://imageshack.us/m/850/5933/168mh.jpg
Cheers guys.
https://www.sau.com.au/forums/topic/364831-grey-spots-on-underbody/
Your assumption is probably correct due to...
* edges of the sprayed area being indistinct
* paint being in areas where snow would have been thrown up (along with the salt).
One just can't tell without a closer look and poking around as to which parts were surface rust and which were deep-seated
That's what I thought as well, but I've also been told it's a paint that is applied at the factory that acts as a sort of sound deadener, but you can't see it on most cars due to years of dirt etc that covers it up and such. I was even shown a picture of another car which is of the same year... or maybe a few years younger which had the same thing except it was a white paint as opposed to grey, and also had the same amount of underbody paint and the car is also from Tokyo. I was under the impression that it didn't snow there as much as in other parts of Japan. Could be wrong though.
Cheers.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
