hey guys,
i need some help, my brakes lights arnt working but my rear park lights are, so it cant be a fuse. I recently pulled my dash out and fitted white dash so there is a good chance i knocked something on the way, i dont know what im looking for...
im thinking it must me something to do with the brake pedal switch thingo...
can someone please point me in the right direction??
thanks guys
It can be a fuse - the brake lights and tail / park lights are on two separate circuits.
Unlikely that all four would go at the same time, but you've checked that the globes are still OK?
There is possibly a fuse in the block under the steering wheel (don't know 33s that well).
The globes are "twin filament" type - one filament is the tail / park, and the other is the brake. It's possible for one filament to blow and not affect the workings of the other filament.
The fact that your hi-level brake doesn't work as well suggests a fuse. Or the switch on the brake pedal has been disconnected / broken.
with the 33's is there a "sensor" at the peddle, at the back of the stop peddle there my be a thing that when you stop, pressing the peddle depresses this button which sents the signal to the lights to get them to work, it may be the problem, if its there adjust it ?? then again if the 33's don't have this thing then its something else!!
It's a simple on-off switch. When the brake pedal is "up", there should be 12V on one side of the switch. When the pedal is "down", there should be 12V on BOTH sides.
Bingo.. :( thats the thing that stopped my stoplights from working all i did was adjust it and they worked fine, hope this is the case for the 33's??
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
