“I know that when I pull up at the lights I’m not going to get one pull up next to me
where is he, bloody alice springs???
looks like he's got a nice myoolay too
Can't be Alice, he'd get Duncan giving him race face at the lights. :uh-huh:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
