Hi,
Car nut? Well it should read more petrol head. If its got a motor Im interested. Of course if its unique and fast then you've really got me.
I like to work on the cars myself, i'll usually do about 80%. 20% given for Dyno tuning (Some may disagree %).
Previous and current rides:
XB GT coupe. (think mad max)
GT mk2 Cortina 1968.
TX3 4wd turbo. (140kw at wheels)
Swift GTI(modified)
S2000 (light mods)
200sx (light mods)
Mustang 67 (mild mods)
Forester Xt (heavily moded)
Just showing that i love all cars and off course Nissan's.
The Foz that Im enjoying now is real fun.
Unassuming and quick.
Just some of the specs and mods:
2.5lt turbo
Mod sti turbo
F pump, reg, F lines
intake Manifold, exhaust
coilovers, s bars, links, lift kit
4/2 spot brakes, B lines, R pads
Strengthend box with a ppg rwd spool.
Spec C diff 4.44 , Axles and hubs.
200+kw in AWD mode.
Hope to have fun with this club at future events.
1st will be I hope, Deca.
Thanks for reading,
Stan.
https://www.sau.com.au/forums/topic/365170-hi-car-nut-here/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
