Hey all,
Just a quickie, got a mate doing my clutch for me (i'm hopeless at fault finding, he's picked up a few issues as he goes), anyway, he was saying I need a bigger master cylinder to run my new clutch.
Interesting part is, apparently the one I have in there is 5/8th inch bore, whereas standard is apparently supposed to be 3/4 inch, he was saying he needs 3/4 inch or 11/16 inch to run it properly.
Just curious, why would the 33 have a 5/8 inch bore master cylinder when standard is supposed to be 3/4 inch? something to do with pedal stuff?
Also can anyone confirm that standard bore is 3/4 inch before i go blow $160 on a brand newy from JJR :)
https://www.sau.com.au/forums/topic/365215-master-cylinder-query-r33/
it's a custom one by Jim Berry, but from what I can tell the master cylinder isn't standard, but smaller than standard
I just wanted to try confirm whether standard should be a 3/4 inch bore rather than 5/8
It should be 5/8.
Slave cylinder is 3/4
Ahhh shit :( according to RHDJapan the standard is 3/4, cos the Nismo upgraded cylinder is a 13/16 inch..
I called Jim about and he thinks it was 3/4 as well, well shit I bought the cylinder.. so i guess if it doesn't do the job, I have a brand new master for a 33 for sale!
haha
haha
Nismo don't do an upgrade for the master cylinder
Nismo do a big bore SLAVE CYLINDER. Factory standard on the slave cylinder is 3/4. To get a lighter pedal feel, you enlarge the bore size on the slave by one size (3/4 up to 13/16. You also get less effective pedal travel with the enlarged bore slave so be careful with heavily modified clutches with a lot of pivot mod for extra clamp. They already have a deficiency for pedal travel due to the pivot being so far. That, combined with a large bore slave 'might' cause you issues when it's trying to disengage
The master cylinder (which is what you asked about) is 5/8.
*pretends to shoot self in head* f**k! hopefully this new one might just be the ticket, maybe the other one is shagged out or something... i'm supposed to be driving up home for a week in a weeks' time!
ok, so if I have the cylinder machined out to a bigger size (not sleeving the slave, it's brand new), is there any internals you're aware of that would replace the internals properly (say, 3/4 inch guts)
maybe a patrol or cruiser or something?
Ummmmmm
Why go to all the effort of boring it out etc. If its wrong go to an import wreckers and pull one off of a turbo skyline. Will cost you $50 and take about 20 mins rather then sending it somewhere, waiting for them to bore it or whatever then getting it back and re-installing it. Seems like a waste of money to me
Can you confirm which cylinder you are talking about also, and maybe provide photos of both so people can confirm if its a non turbo item. It seems weird that it would be smaller as I dont hear of them stuffing up to much.
It sounds like your a bit confused between the master and slave and there sizes
it's all sorted, i got mixed up as the Japs call the slave the operating cylinder, but it's all good, just ended up sleeving the slave down to 11/16 from 3/4 and yeah i was mixed up, not too up to speed on clutch components yet (haven't got that far in replacing/repairing or my degree! only up to engine stuff now!)
Oh it is a turbo skyline btw..
And for those interested, the STANDARD bores for Master and Slave are 5/8 inch and 3/4 inch respectively.
No no no no no!! I may have not worded it right, the standard slave wasn't fully engaging the clutch, it was about to engage at the floor when it was standard bore, so it wasn't actually engaging the clutch. The sleeving down to 11/16 made it heaps easier to use, and as for how heavy it is, well, it's light as compared to what it was when I had the OS Giken twin plate in it... MUCH lighter, this is like almost a standard clutch in comparison
Sounds like you've Bandaided it? Was your pedal alright, as in did it have to much play?
Seems weird, never heard of a clutch made for a skyline not engaging properly in a skyline when everything is correct. I'd check for another problem.......
  • 1 month later...
The mechanic doing it had a lot of work to do to get it engaging, including f**king about with the pedal box and such, eventually we decided to give it a more positive and not an at-the-floor engagement to sleeve the slave, the pedal is barely noticeable, it is lighter than it was with the OS twin under it, and there shouldn't be problems I have a brand new master in it, rebuilt slave when it was sleeved, next fix will be braided lines but still, there's no problem with the pedal travel, it engages maybe 100mm from the floor, before we sleeved it, the problem was with the pedal, it was just engaging at the floor
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
