Driving Sport inc
Twilight Drift Friday the 3rd of June
Fusion Car Audio Sound off and show n shine
Driving Sports inc Twilight drift at Eastern Creek Raceway
turns 9 to 12 Entry fee 220 non members + CAMS $57 or ,180 full members
9 to 12 is a good news, bad news situation
The bad news for now is we have less corners , but it is a bit cheaper
The good news and the reason we can only run 9 to 12
is the track redevelopment is going ahead
So we can look forward to more and different corners in the future
EC have not given a exact time frame on when it will be finished
as we have more info we will keep you updated
Driving Sports inc Twilight drift at Eastern Creek Skid Pan (wet)
Entry fee $150 + CAMS $57 non members ,$110 full members
Driving Sports inc Twilight drift at Eastern Creek Figure 8/peanut (dry)
You can chop and change between the wet pan and figure 8 when you like
Passengers in cars with out a cage on the wet skid pan is ok .
Minimum cams approved half cage for passengers on the figure 8 and main track
FUSION car audio
Sound off Entry Fee =$ 30
Show n shine Entry fee =$ 20
Entries will be capped
So book now
please do not wait till the last minute pre paid entries will only be accepted up to Tuesday the 31st may
so send a deposit now and lock in your spot before we are full
Entrants for on track activities will receive one pit crew pass and one pit/ paddock car pass
On track activities start at 6:30 pm and end at 10:30pm
Scrutineering. For entrants starts at 4:45 pm at gate 7
Heaps of action for drivers and spectators With 3 different dedicated drift areas, DJ and light show in the pits , sound off show n shine , give a ways/prizes, hire a drift car plus more
Entry fee $20 for spectators kids under 14 free
To book go to www.drivingsports.com.au and fill in a entrant form
Or if you would like more info email us [email protected]
if you have never been out to one of these follow the links below
for pics and vids
thanks to Matt everingham for the pics and blog
http://mattheweveringham.com/?p=639
thanks to jason from redbak photo for main track pics
and kory for the pan and F8 pics
http://www.koryleungphotography.com.au/gallery/DSEC20110430/index.html
Edited by KLR33
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
