I think you are looking to win the highest boost without a boost controller on a stock turbo award! (aka "I tried to break my turbine" award also know as the "excuse to buy a new turbo" award and the general "boost is king baby stupidity" award).
I think whether or not you use a labelled 'boost controller' to achieve this highest boost thing is irrelevant. I used collected boogers and straw to get 18psi on mine but it broke the turbine.
https://www.sau.com.au/forums/topic/36538-hightest-boost/#findComment-730315
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
