why the hell would I buy a Lexus? 270,000km owned by Qoc Nguoc Phan Tran who services it at a backyard Gull servo mechanic
Signature worthy. Epic!
I think the electronic shifting is awesome, I just want a manual so I can drop the clutch and have a finer control over gears.
Also, I think majority of Skylines in Australia that are sold on are thrashed and f**ked, or just not worth the asking price. Why when you can buy something in much better condition in Japan, import it and comply it and still have less KMs and pay less.
  • Replies 59
Andrew - am saving up to import again, I have not purchased the car yet obviously, but yes... In about a year or so time I will have a crown majesta..
And haha, eps... Why do you have that name that's gonna get so confusing haha
But it's true though. The only people that buy Lexus are Chinese or rich Vietnamese. And Jewish people,
And they seem to REALLY drive them. A LOT.
That's not racism. It's just fact. Oh and Indonesians love the third gen GS and the RX too. Haha
^^^ this. . . i have a auction sheet (with pics) in front of me and i doubt that i will be buying a sedan in aus, not when there are cheap /low K examples waiting to be snapped up in japan
Most Japanese cars are in good condition and well worth the little extra wait :)
Definatly worth the wait , ive been in contact with Kristian from IRON CHEF , so far so good, he has sent me some more auction sheets and there are PLENTY of good condition sedan worth waiting for, nearly all autos ( but i dont mind that as i believe the fluid filled auto trans would help dampen engine harmonics) and only a few manuals, most grade 3.5 and up
Put it this way, in the import market... A 10 grand total budget will likely yield you quite a good black coloured ER34 with a lot of fruit on board like wheels etc....
And more than likely depending on the exchange rate at the time, will PRObably get you change back from the transaction ...
But either way... Importing an ER34 into WA is feasible because the market here is so inflated for them... So it actually makes sense. Personally I'd get a Toyota because I think they're built much better.. :)
My other piece of advice? Stay away from WA compliance shops. I hear good things about a particular shop that's on here that DOES lurk these forums and that shop IS good however stay the hell away from that yellow shop with the kangaroo in overalls on the logo.
That guy is a prick. A grey haired... Greedy .. Lieing... Prick.
which is the good shop you speak of?
GT -> Basic 2L
GT25 -> Same as GT, but with 2.5L engine.
GT-Four -> Same as GT25, but with AWD
GT-x -> Same as a GT25. Equivalent to a premium model equipment wise, ie. factory privacy glass, double din "premium sound", xenon headlights, front strut brace, optional LSD, optional GTt wheels.
GTt -> turbo model of a GT25, with big brakes, HICAS, LSD
GTt-x -> turbo model of a GT-x, with big brakes, HICAS, LSD
GTv -> Same as GT25, but with big brakes, HICAS, LSD
Thanks Mark, thats the sort of info im after :thumbsup: these sedans are just as well equiped as the coupes . .just with two extra doors
Prices seem very unpredictable of late. We've watched cars go for a lot more than they should. Last week I was bidding on a 3.5C, auto 4 door GT-V 50,000km that went for Y650,000 - so about 15.5k AUS landed and complied.
The week prior a 4.5B, TV2 4 door manual GT-T 65,000km went for Y1.9Million. That is silly money. That is 34 GTR Non-Vspec type of coin.
It is hard to pick a great condition cheap car at the auctions currently. I have found cars locally to be very well presented, with low km's and very cheap. I'm considering looking locally for my 34 4door instead of at the auctions for this very reason. Why pay 16k L&C when I can pick a comparable car up loacally for 4-5k less?
Ive found the opposite so far, ive gone thru 200 pages of cars for sale on SAU (some with mods) and a lot of auction sheets and after comparison i reckon i will come out on top by importing a skyline
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
