r34 5 stud rear brake setup,hubs,hand brake cables,everything there needed for conversion $300
diff with 5 bolt half shafts 4.111 $130
all arms $40 each
hicas rack $40
bare subframe $80
drive shafts $40 each or $70 the pair or take the complete subframe for $550....
front lower control arms $180
steering rack with x member $150
front hubs $30 each
washer bottle $20
one reverse light off a 2 door $30
stock caster rods $30 each or $50 the pair
clutch & brake pedal $400
clutch master cylinder $40
clutch fan with fan $60
air con compressor $150
r33 washer bottle $20
r33 rear subframe all arms there,hicas rack $150
r33 drivers door with glass silver $100 straight as! last time i checked.
r33 stock front pipe with cat $40
r32 2 door tail lights $80 the pair
r32 power steering pump $40
r32 aircon compressor $100 has been freshly serviced not long ago
r32 aircon condenseor $80
r32 gtr front bar with lip and mesh minor damage easy fix sms for pics $300
r32 gtr resistor pack $40
located in sa athol pk 0422030855 will post smaller not heavy items
Edited by hcR324door
https://www.sau.com.au/forums/topic/365710-r34-parts3332/
Sorry, from a manaul r34 turbo viscous LSD abs
OK. That needs some clarification. Which part are you most sure about....the viscous or the manual? Because as far as I know, the manuals have a helical and the autos have a viscous diff. I am particularly uninterested in a viscous one!
https://www.sau.com.au/forums/topic/365710-r34-parts3332/#findComment-5841684
all arms $40 each
hicas rack $40
bare subframe $80
front hubs $30 each
washer bottle $20
one reverse light off a 2 door $30 passenger side
clutch fan with fan $50
r32 gtr ignition resistor pack $40
https://www.sau.com.au/forums/topic/365710-r34-parts3332/#findComment-5861216
  • 3 weeks later...
I would be interested in the cv joints/drive shafts if that is what you mean for $40 each or $70 the pair.
Would you consider sending them up to Brisbane on courier?
Cheers
Yes at your exspense pm me
https://www.sau.com.au/forums/topic/365710-r34-parts3332/#findComment-5893084
  • 4 weeks later...
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
