Brand new in box Precision Turbocharger 900HP with similar spool to a TO4Z
6765 billet wheel dual ballbearing waterless centre section
T4 .81 open scroll
4" inlet 2.5" outlet ported shroud front cover
3" exhaust outlet with clamp and flange
oil drain flange
Cost $2500 from powertune
Sell $2200
Edited by Ryan1200
https://www.sau.com.au/forums/topic/365908-precision-turbocharger-6765-bb/
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
has it got the compressor cover with the surge slots or drilled surge holes?
might be keen on this, hoping it has the slots as i am not a fan of the holes what so ever :(
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
