Hey everyone!
I'm not that new to the Nissan badge :) had a few imports over the years and I'd never own anything else.
My names Loren or Lawz I'm happy with either. However, I'm very computer illiterate and easily confussed.
Just looking for some pointers on this website. I have been registered for a while.. It confussed me and I gave up. Giving it another go :)
I own a black r34 gts-t and I'm telling parts off an r33 gts-4 na if anyone is interested :)
https://www.sau.com.au/forums/topic/365913-computer-illiterate/
You're joking, right?
Ohh and no. R33, gts-t. I have not been won over by the r34's as of yet. Not so keen on the tail lights and just the general all round look. I have been yet to be impressed by one.
Edited by LawZ
Typing error where?
Also, if you weren't joking.. then no.
Thank you, DIVHUNTER.
However, sorry to generalize. But, being a female skyline driver you get use to men and their strange sense of humor. You learn to ignore it.
Well if you actually wont to get technical, i do know the difference. So how about you shut your face, until you actually get the facts. I use to own a r33 gts-4, also a gts, i know own a r33 gts-t. One of with r34 mods. I made this account when i owned my naturally aspirated r33 gts-4 and i have since upgraded and own several more. So if you wish to go critizing my intelligence how about you get the facts first. Thanks :)
As for all the ridiculous, sarcasm and comments. Grow up!!
Well if you actually want to get technical, i do know the difference. So how about you shut your face, until you actually get the facts. I use to own a r33 gts-4, also a gts, i now own a r33 gts-t. One with r34 mods. I made this account when i owned my naturally aspirated r33 gts-4 and i have since upgraded and own several more. So if you wish to go criticizing my intelligence how about you get the facts first. Thanks :)
:) u.mad?
so you own an r33 with r34 mods?
Edited by ClutchBurndout-:(
Mad, is an understatement. Men believe they know it all and simply just don't like a "chick" actually knowing what she is talking about.
No at the moment i own a R33 gts-t. My r33 with r34 mods, has been crushed. So it is no longer a car nor apart of my collection. Photo's are up on facebook if you wish to view them.
im still confused
ok you HAD an r33 with r34 mods
what is an r33 with r34 mods?
why u somad?
chill bro
your fb only has the black car in your pic, do we have to add you to our facebook to see your photos?
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
