When i let my car warm up in the morning, i let it sit there for a about 3 minutes.
But i've noticed that sometimes there is quite a lot of black oily soot that comes out onto the asphalt from my exhaust.
Is this normal? I'm hoping it's just because my car is running really rich?
I had my car compression tested a couple months ago and all cylinders were perfect so I imagine that this would be quite normal for a car running rich right?
https://www.sau.com.au/forums/topic/366173-black-soot-coming-from-exhaust/
FWIW Its better for the motor if you drive smoothly (no boosting, rpm below 3000) to warm it up.
Nothing to worry about. If you see a lot of black smoke when you're boosting then you should probably get it tuned.
Thanks Adam, I suspected as much, but thanks for confirming it's nothing to worry about.
Yeah i've heard that just driving it below 2500 - 3000 rpm and off boost is better - maybe i'll give it a shot. In the morning though, i think that i'll still let it sit there fore at least 30 seconds before i drive off.
condensation occurs in the exhaust when the car sits, it mixes with the soot that is naturally in there. First start of the day blows most of it out, our cars are more prone due to bigger exhausts that allow moisture in there easier. If it happens when warm and under acceleration then it is proably too rich
The soot would be from a rich mixture wouldnt it?? like from the previous days drive, where you might have squirted it and the car ran rich a few times then in the morning the condensation is washing the soot out , dripping onto the asphalt.. correct me if im wrong..
i give it 5mins idle, and baby it for another 15mins
it could be from a rich mixture depending on the condition of your O2 sensor or how well your cat is/isnt working-either way it sounds like you dont have much to worry about
Thanks, yeah i'm pretty sure that it must be a rich tune now.
It's still running the Jap tune on the Apexi FC from before i imported it to Aus.
Also, it's running a high flow metal cat, not sure if that would somehow contribute to the situation though.
idling for 5 mins is a waste of fuel, and is probably doing more damage than good. the reason being that at idle the car takes longer to warm up than when driving sedately, plus the fact that only the engine oil is heating up and not the gearbox or diff oil. also some people say that at idle you don't get quite as good combustion so you have the bores being washed down by fuel a bit and this reduces the ability of the oil to lubricate. generally speaking, 10 mins of sedate driving should be enough (15 in winter) as long as your thermostat is working properly as the coolant temp should be approaching operating temp within a few minutes.
as for the soot on the ground, as someone said above, it is just condensation mixing with soot.
i see your point, and people can do whatever they like, but ive done the drive off straight away like your talking about, when i do that the engine feels very tight like its full of friction, and the gearbox will crunch second gear too,
I have a tuned power fc which shows coolant temp of 50degrees or more by 5mins, the gearbox also changes sweetly so it must be warming up some what too
as for fuel washing cylinders, i use a good dose of lucus upper cylinder lube in my fuel, and im not sure if 5mins stone cold on 2000-2500 would be better than 5mins to warm up first, but its all speculation unless you can prove stuff scientifically.. until then ill stick with my padantic method, lol...
What engine oil and gearbox oil do you use? I believe thicker oils cause more damage at start up (but its still an almost insignificant amount). FWIW full synth oil is more consistent across temperature ranges than dino.
I don't think coolant temperature is a good indicator. My coolant temperature gets up fast, the oil takes a lot longer. I keep things sedate until my oil's at 70 degrees on the gauge, which is where it stays during normal driving. So full temp.
Re: your response to Mad's comment on fuel washing cylinders - if you want to know for sure, get your oil tested. One of the things they test is fuel contamination. Mad has the theory correct, but the effect may not be significant in your case.
I use MOBIL 1 GOLD for engine 0-40, gearbox has nulon semi with a litre of mobil Gold to make it light, most box's are a bit worn though hey :dry:
Hmm, think ill get an oil guage, sounds like a useful gauge to have :mellow:
yeah it was a good point, i agree with that you both :thumbsup: and also they use lucus on the drag cars too, bit of insurance .
apologies for getting this convo off topic of the soot issues etc...:unsure:
do you have an oil cooler or something?
that seems very cold for oil, the oil in my old r32 and my r34 now both run at 92ºC at full temp.....
if you were to drive off after about a minute of idling you'd probably find that you would get to over 50 degrees after about a minute or two of driving (so probably about 2 mins faster than by letting it idle).
I do, an HKS kit, but its thermostated IIRC. That's just what the gauge says, so no idea if the calibration is off, but the needle location is consistent. It goes up with track work, but i back off once it reaches 110 (it would keep going up).
Hang on - did you say you are thinning your gearbox oil with engine oil?? :blink:
I'd say that's a very bad idea....
yeah well its either that or crunch some gears or go get the gearbox rebuilt, so i choose option A
Im pretty sure a gearbox shop said i could do that and get away with it, when i had a mazda the dealer said in severe cases of gearbox trouble, you can even use automatic gearbox in a manual, :O and that stuff is like water... which ive done and it fixed up the crunching second gear,.... but i stress its a last resort and not recommended of course..:no:
But the proof is in the driving isnt it??? when i bought my car i was crunching 2nd when cold, and 3rd was kind of jarring like it didnt want to go in, and now i have none of those problems so obviously it cant be that bad..:thumbsup:
good point , but by the time i get the thing out the shed and out the front gate, its close to 5mins, lol.. :/
can just imagine what the neighbours think, booooarrrr booarrrrr, hahah, soak it up people its an annoying rb, :banana:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
