  • 3 months later...
Hey guys,
just changed the batteries in my remotes. Everyday key works fine but my spare does not lock/unlock etc. When i first took possession of the car i had a factory upgrade done to immobiliser/alarm so that i could utilise factory keys, any reason why one would work and the other would not?
Any takers...Chris lol?
Maybe one was for factory immobilizer and the other for the upgraded immobilizer, the installer took out or disabled the factory one so it does nothing and thats why the other key just unlocks the upgraded alarm and your factory key does nothing?
This may be useless as i dont know what key you have but...
http://infinitihelp.com/diy/common/infiniti_reprogram_key_fob.htm
Edited by R6n350GT
http://infinitihelp....ram_key_fob.htm
would absolutely LOVE to see that one done..
as for a dead remote. I would check that you have a good battery in it and it is the right way up.
To install a Haltech Platinum you need to rip the whole immobilizer out ... so if you would love to see that then ask Rossi who has had it done.
Any actual advice other than check the battery... i was only trying to help.
Edited by R6n350GT
I put a brand spanking new battery in the remote and definitely the right way up lol.
I called up the shop i had it done at cos one of the lads also has a V35. He said his is the same and has NFI why, is enquiring with Nissan to try and resolve.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
