guess what car is for sale:rolleyes:
NISSAN SKYLINE 1992, GTST coupe, automatic, air cond, climate control, electric windows, pwr/steer, 4 wheel steer, Kenwood stereo system, custom paint job (worth $8000), custom bar, billet wheels, 3inch custom exhaust, boost gauge, blow-off valve, 1st stage boost 12psi, super low springs, award-winner at Auto Salon, real head-turner -$25000 Kingston (0413) 243 925
https://www.sau.com.au/forums/topic/3668-sacrilege/page/2/#findComment-61340
i must say I really do like that car, especially the paint job. THe only things that bother me are the wheels (not my style, but some how do still fit in the theme of the whole thing) and the number plate "26 BUB" gives the impression it has an rb26dett in it.
Anyway, I like, each to their own.
Greg. :devfu:
https://www.sau.com.au/forums/topic/3668-sacrilege/page/2/#findComment-62818
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
