Hey guys, so my 32gtr is still giving me grief and I have absolutely no idea how to begin the trouble shooting process. I have the complete service manual and basic tools.
I am wondering If there is a gtr savvy member living around the maylands area who is interested in spending a few minutes answering questions and having a look at my car(try and get it going properly) for the price of a carton of their choice. I have read through hundreds of threads on this and other gtr sites(Canada gtr is also very good) but have not managed anything solid.
Cheers in advance guys. Here's hoping. :)
Jesse.
https://www.sau.com.au/forums/topic/366889-anyone-keen-to-help-for-a-cost/
  • Replies 180
Well it's very similar to the problem benno2 was having, started her up and let it idle for a few minutes to warm. Cruised slowly around the block(probly 1k) then, going up a slight hill the revs started dropping even though I was still accelerating. They progressively dropped all the way down and the was almost stalling on a rough idle. Totally confused I killed the ignition not wanting to do more damage. About 4 hours later I tried starting it and it started with a regular idle but a bit low and drove back here with
What felt like slight power loss.
What do u guys think? Mass air flow? Hopefully not gasket? Is this a turbo fault?
I'm moving from a 96 v8 fairmont so this is allllll new to me.
Thanks all.
By the way I'm located right by maylands traino.
Jesse.
Ok, so I just pulled my top Afm out to have a looksi.. Previous master has obviously already resoldered our connections here. This is the joins, sorry they're upside down.. :P
And this is what I assume is the O2 sensor.
Very oily/dirty.
What do we think guys?
Thanks for the input. And Boss-Zilla, this is pretty much all I've done so far.
Jesse.
thats the hotwire of your AFM and its filthly lol that will probly be your problem (o2 sensor is in you dump pipes after the turbo), spay it with some electrical contact cleaner, DO NOT touch it with anything, next thing is to figure out where that oil came from.
Edited by horrace
That is the hot wire (sensing) element in the airflow meter, O2 sensor is in the turbo dump pipe.
And that looks like a shitload of oil on the afm, look up the cleaning DIY and see how it goes.
Got a catch can?
Edit: beat me to it horrace!
Just need to clarify, really I meant an oil/air separator.. contains baffles etc and is used to scrub oil from the air before returning it to the intake stream. Always a good thing on a boosted, legal, recirculating breather setup.
A catch can just catches any oil that may come out the breather and is a safety measure required in some racing, usually used in atmo breathing setups (and in recirc setups by people who bought cheap catch cans off ebay).
Jesse, to me it sounds like a vaccum leak and another possibility is intake manifold gasket leaking.
Have a look in the workshop manual for the vaccum layout, will show you all the hoses - make sure they are all good.
To search for leaks in intercooler piping and manifolds, grab a can of Aerostart or similar and with the engine running, spray around all the joints in the cooler piping and intake manifold - if the revs pick up you've found your leak.
Oh dear, most of the vacuum hoses look like this; (these are top and bottom turbo control solenoid hoses respectively)
I'm about to go get some aerostart to test em but I think they will all need help soon. At least if I can get it driving ok I can get it to a mech.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
