So guys, I decided that I needed a change.
I didn't love the rims that came with the car when I bought it... so I painted them!
Before manhandling:
post-51018-0-09779800-1307405591_thumb.jpgpost-51018-0-41651000-1307405603_thumb.jpgpost-51018-0-67092000-1307405611_thumb.jpgpost-51018-0-38549700-1307405631_thumb.jpg
Rims, washed and sanded:
People say that you should sand the rims down completely, but I didn't notice a difference. So I didn't bother too much with the sanding until your hands bled...
Car jacked and surface covered for caliper painting:
post-51018-0-13768800-1307405803_thumb.jpgpost-51018-0-75615900-1307405809_thumb.jpgpost-51018-0-70926200-1307405817_thumb.jpgpost-51018-0-81933600-1307405825_thumb.jpgpost-51018-0-80161300-1307405836_thumb.jpgpost-51018-0-57514400-1307405844_thumb.jpg
My car was too low, and i couldnt get my heavy duty jacks to fit. So I had to use the little one that came with the car. This is why you will notice 3 jacks!
I gave the rims a few light coats then followed up with a few heavier coats, and then finally a clear coat to make it shine:
Capilers after a few coats:
The final product:
post-51018-0-24224600-1307405889_thumb.jpgpost-51018-0-08954300-1307405897_thumb.jpgpost-51018-0-29249000-1307405905_thumb.jpg
Nothing is more satisfying that admiring your own work
https://www.sau.com.au/forums/topic/366974-painted-my-rims-calipers/
*drool* V36 coupe + black on black.... noice! :D
Did you put clear over them when you were finished?
Before manhandling:
The final product:
yeah bro,
it looked kinda matte black so i put a clear/gloss coat at the end. really made them shinnnnny
i will put up some better pics on the weekend
apparently the paint will start flaking or peeling off later on because you didnt sand them back.. maybe you should off tried a more course sandpaper...
i sanded down the scratches before painting.
i had painted the rims on my v35 a few years back and the paint didn't chip or flake after 2-3 years of use.
i think it all depends on the paint used, maybe?
Nah, the paint will key better to a painted surface than to bare aluminium; unless you're going to go ther whole hog & etch prime, prime, paint, clear etc, etc. And if you were doing all that, you should've stripped of the rubber too. If the paint was already flaking off, you might've had a problem.
That will stay on fine. Red calipers breaks up the black just enough.
Good job man, that looks awesome! Did you notice much of a change going from V35 to V36?
The 2 main reason why i upgraded to the v36 was because the v35 (2003 premium model) was starting to show it's age ie the windows stopped working, the acceleration was starting to lag. Also, there were v35s EVERYWHERE!
yeah you do notice the difference between the 2 cars ie power & interior upgrades. I absolutely loved my V35, and it was the obvious choice to stick to the brand you love. :thumbsup:
Fingers crossed
What?! Man I probably see two V35s every 3 weeks. And thats including mine. :)
Great job on the wheels though... I'll be next to do this to my 18s standard wheels but I was going to get them sand blasted first.
I also was going to buy high temp paint though. Is that what you used?? Do you think its necessary?
And I have this liquid metal to fill in the scratches before I start painting.
Mike, there are 2 in my building and 2 more on the street where i live. So i see them every day :P
I bought VHT paint, they are good for brakes and wheels. Don't skimp on the paint, I think it will bite you later on.
I sanded down the scratches before i started painting. That's what i would do, unless you have some serious damage.
GOOD LUCK
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
