OK, just a heads-up, warning and request all in one.
Recently a few issues have come to light with the amount of nicknames a group of us (who know each other very well) call each other.
Now I have not had a problem with any of it until now, but from both a personal respect and website/SAU:SA club policy, I feel we need to set a firm policy on this.
So, as of NOW, I want everyone to completely stop any nickname which ANYONE could find offensive - whether it be regarding their skin colour, hair colour, previous behaviour or any other reason anyone might take offence. 1 warning will be given to offenders, then they get a ban from the forums. If someone PMs me and says they are offended by an individual, I will act on it.
I know in the past it has all been in good fun, but as of now it is no longer ok.
I get that this can be a serious issue, but come on guys, I havent heard someone have to give a talk like that since primary school. I believe a teaspoon of cement and grain of salt is in order.
I find it offensive and ignorance when people use the term "Jap". Many dont mean anything by it but it is rude and you wouldnt want to use the term when speaking to a Japanese. I know this is an abreviation but always found it rude. Instead use the full term or JP for short.
Guest
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
