firstly i would say check ALL OVER THE CAR for a pink / green / purple plate etc etc.. check in the door jambs on the passenger door..
if it's still not there i would be inclined to say that no, you will definitely not be able to get that vehicle complied with an RB26. or possibly comply it at all...
that said - i see you're from queensland - and from what i see over there, it's pretty much anything goes if you slip em a XXXX!!!! ahahaha
LOL yer wish it was that easy
i looked every were its like some one half tried to comply it cos its got the side intrusion bars but just no paper work and no green plate
no wonder it was cheap
are you brissy based? if so I can probably help in a way.
whn you bough it was it registered at all or had it been through registration?
do you have a chassis number at all?
i'm in central qld
it hasn't been registered no aus vin number just the jap one
ok ,
when you bough it did you get ANY of the import paperwork with it?
if so contact a RAW that can comply your type of car and tell them the story. www.raws.com.au will give you a starting point.
if NOT then you have a track pig only. it cannot be registered here.
My car is currently registered, but the compliance plate has been lost from a re-spray and re-build. now the previous owner is being a C&*T and doesnt want to help me in any way. I dont have any import papers, just the new aussie vin has been stamped on the drivers strut tower. Is there anything you can suggest Chris for me to get a replacement so I can get a roadworthy?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
