Hi guys and gals.
Here's the back story, Had my skyline yellowed and didn't have the time to get it off till recently (been bout a year).
The whole time the car was off the road i started it every other week to let it tick over (plus i love the sound)
Finally got it squared away and it passed the pits first time yay.
But just recently cylinder 5 has been cutting out WTF?
I narrowed it down to cylinder 5 by pulling out the plugs for each coilpack until the missing sound didn't change. I originally thought coilpack so
I changed pack 4 and 5 around but cylinder 5 still dropped out but 4 was fine. so i changed around the plugs same again. Sprayed all plugs, coils
and connections with contact cleaner still nothing.This is really giving me the shits as it happens on and off so im thinking either ECU or harness.
If anyone has had this happen to them, has an ideaor has a coilpack harness I can borrow to strike that from the list I'd love to hear from you.
Cheers people
Gavin
https://www.sau.com.au/forums/topic/367444-help/
series1 or 1.5/2???
if series 1 try getting a hold of ignitor pack to try as well cause my 32r was dropping cylinders 6 & 4
and did the same thing changed plugs coil packs even did other things then chucked on a different ignitor a pow all fixed
https://www.sau.com.au/forums/topic/367444-help/#findComment-5861774
At this point in time I think i need all of you to form a line and kick my ass :spank: .
I finally got round to checking the ecu with the help of a mate and it turns out the harness plug wasn't
all thje way in on all sides even though it was bolted in. It must have been done when the inspector at the pits had the kick panel off
having a look to make sure the ecu was standard I'm guessing, as i didn't have this problem
till I got backfrom the pits. So far the car hasn't missed a beat so fingers crossed that was the problem
and not something else.
Thanks to everyone for your help Ifeel like such a dumbass :blush: .
Cheers
Edited by Gabbo2047
https://www.sau.com.au/forums/topic/367444-help/#findComment-5862347
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
