For sale is my R32 GT-R V-spec II. I purchased it off an older bloke who has had it since 2006. Being a one of the last R32 GT-R's and also being a V-Spec II, it has some extra goodies like Brembo calipers and a more tightly tuned ATESSA system. I had my eye on an R32 GT-R for about a year before I stumbled across this beauty. There are NO rips on the seats at all. VERY rare on R32 GT-Rs. This is a testament to the condition of this vehicle.
Since the new engine has been in, it's done around 4000 kms bringing the odometer to a total of 37xxx kms. The oil has been changed every 6 months and not 5000 kms, as it never reaches even reaches that in half a year. The only oil that has touched this engine since I've had it is Motul 300V.
I really don't drive it much, as I have a daily to drive to and from work. This isn't an urgent sale, but I wouldn't mind upgrading to an R34 GT-R.
1994 R32 GT-R V-Spec II in KR-4 Sonic Silver
All parts were purchased BRAND NEW (if available) by either the previous owner or myself.
Engine:
60,000 km R34 GT-R engine - ($5,500 from JPC)
High Octane baffled larger capacity sump - ($1,550)
Nismo 1.5 way front diff - ($1,500)
Garrett GT35R turbo - ($1600)
6Boost manifold - ($1200)
Spitfire coil packs - ($600)
Turbosmart 50mm external wastegate - ($800)
Sard 700cc Injectors ($1000)
Sard fuel rail ($450)
Sard fuel pressure regulator ($250)
HKS adjustable cam gears ($300)
HKS 272 cams ($1300)
Trust oil filter relocation kit/10 row oil cooler ($1100)
Custom intake and heatwrapped dump/front pipes
Bosch 044 fuel pump with direct power source ($250)
Hi Octane rocker cover baffles ($270)
Gates heavy duty silicon hose kit
New braided oil and water lines
HKS intercooler ($1000)
Apexi Power FC Dejetro & hand controller ($1500)
Greddy Profec B spec II ($400)
HKS Silent Hi-Power exhaust ($1200)
Exedy heavy duty clutch and lightened flywheel ($2000)
Wheels and Suspension:
Work Emotion CR-KAI 18x9.5 +20 in MGM matte gunmetal with blue Rays duralium lug nuts ($2100)
(Can include ORIGINAL V-Spec II 17" rims)
Federal 245/40/18 all around with 90% tread ($1000)
HKS Hipermax LS+ coilovers ($1950)
Cusco camber arms
All polyethylene bushes
Sound system:
Complete Rockford Fosgate system consisting of:
T-2652S Front Splits ($799)
T-1693 Rear Coaxials ($399)
T600-4 4 Ch Amp ($1299)
Alpine CDA-117 ($529)
4 Gauge wiring kit ($149)
Etc:
N1 vents
N1 boot lip
N1 side skirts
N1 rear spats
HICAS removed and lock bar installed
Whiteline front & rear swaybars
Cusco strut bar
HKS oil cap
HKS radiator cap
Total of $30,000+ spent on parts alone on top of purchase price.
That's all I can remember off the top of my head. I'm sure there is more I've forgotten to list. Has been tuned to make around 440rwhp @ 18 PSI by Sean at All Star Garage. Could make more with a re-tune as this was a conservative tune. I have the dyno sheet for serious buyers.
If you're looking for a cheap, neglected R32, look elsewhere. On the other hand, if it's an immaculate, no more money to spend GT-R you're after, give me a call on 0466653693. I can guarantee you won't be disappointed.
Car is located in Perth, W.A.
Price is $28,000 or nearest offer
https://www.sau.com.au/forums/topic/367554-r32-gtr-v-spec-ii/
  • 3 weeks later...
  • 3 weeks later...
That looks like the parking lot outside Domino's myaree etc :P
Mate, All the best with sale. If it were a few months down the track i'd snap this badboy up in an instant. Certainly one of the nicest 32s i've ever seen. I hope she ends up in a good home thumbsup.gif
  • 3 weeks later...
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
