actually sold to me :no:
Payment done on 11th july but no news since. Can I get some update please ?
And can one wait to close this post ?
Correct. Sold to Wardiz.
Payment received in full (thanks)
Profec items wrapped seaparately in bubble wrap then bagged for postage.
Sent via Australia Post- (air mail)
To France I have been told you should see it within 2 weeks.
Apologies for not replying to you sooner, been doing odd shifts at work.
