perth W,A registered... JUSTADATO ....number plates white lettering on black polycarbonate For Sale... $1500 ...
please post this here: http://www.skylinesaustralia.com/forums/forum/12-for-sale-private-car-parts-and-accessories/
https://www.sau.com.au/forums/topic/368135-for-sale/#findComment-5871575
should have expected as much from a bunch of skyline drivers....to post in the forsale section it wanted me to sighn up to the w.a site and i couldnt be bothered basicly so i just clicked new post and bombed em up on here...the fact that you took the time to respond to a post you had no interest in just to have a bitch and moan is kinda sad really
https://www.sau.com.au/forums/topic/368135-for-sale/#findComment-5873458
No if you post in RIGHT PLACE its all cool,
But as your a clown & can`t then GET SHIT from lots more,
if we all had your DGFA :domokun: then place would be a mess :cheers:
https://www.sau.com.au/forums/topic/368135-for-sale/#findComment-5873483
Oh I'm sorry deary, couldn't be bothered is such a valid excuse.
I took the time to respond to your post because at the time it was your first post and I gave you the benefit of the doubt that you did not know there was an enormous for sale section.
Please take your plates and go to boost cruising.
https://www.sau.com.au/forums/topic/368135-for-sale/#findComment-5873577
The fact that you want to sell something, but are too lazy to fill out a single, two minute form is quite sad. Then when people try to help you out by asking you to move it to the correct section you get all defensive. All I can say is lol.
Good luck with the sale btw, you're gonna need it now.
https://www.sau.com.au/forums/topic/368135-for-sale/#findComment-5873600
Anyone else find this line a bit hypocritical? Considering you took the time to bitch and moan about everyone else. Maybe post it in the for sale thread, and people would treat you like a retard. I mean come on, if you took all of 3 seconds to scroll down (and thats retard speed) you would clearly find the for sale thread.
Also maybe dont sign up to a skyline site if you think all skyline drivers are idiots. Maybe try ebay, trading post or even gumtree if you cant afford the $2 fee.
https://www.sau.com.au/forums/topic/368135-for-sale/#findComment-5873887
Oh so sorry
Locked.
https://www.sau.com.au/forums/topic/368135-for-sale/#findComment-5874977
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
