hey guys up for sale i got some parts that i dont need for an r32 gtr and need them gone
GTR r32 front left and right doors in gunmetal colour, in excellent condiiton with the windows and the motor for the power windows $300 each
full trims for r32 gtr in great condition- 2 front door trims and 2 rears corner window trims $250
gtr intercooler in great condition- $140
rear reverse lights that locate near number plates - $100
gtr gearbox from r32 gtr had 136,000kms $400
gtr diff- $350
r32 gtr glovebox in excellent condition near handbrake $100
r33 gtst climate control unit - $50
r33 gtst standard cluster with 121000kms $120
r33 gtst silver series 1 headlight - $120
contact via pm or 0412862091
cheers
parts located in melbourne and pick up available
and guys sorry havnt took any pics but will take a pic for whover is intersted as i have been flat out
Edited by gdzlar1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
