Hi everybody,
I've got a few sets of parts I'd like to sell off.
Genuine quality Tomei parts.
These things are truly WORKS OF ART.
PLEASE PM ME IF YOU'RE INTERESTED.
Save time and contact me directly.
Location: Brisbane 4157 - Can easily post this stuff all over Australia.
Tomei Expreme Stainless Steel Exhaust Manifold Kit R32/R33/R34 GTR RB26DETT
Price: $1075 including postage Australia wide bar TAS.
Extra for insurance and registered post.
HiOctaneDirect - $1150 + Shipping
http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=22_103&products_id=719
JustJap
$1400 + Shipping
http://justjap.com/store/product.php?productid=17907
Condition: Brand new
Includes: 2 Expreme Manifolds, 2 Rolls of heatwrap, Metal Ties, Instruction Manual, Gaskets, Sticker, Gasket Paste
Pictures:
Tomei Expreme Dump Pipe Turbo Outlets R32/R33 GTR RB26DETT
Price: $850 including postage Australia wide bar TAS.
Justjap - $1200 + postage
http://justjap.com/store/product.php?productid=16976
Pictures:
BRAND NEW SEALED R32 R33 GTR RB26 Tomei Poncams Type B
Price: $850 plus postage
Condition: Brand New
In/Ex Tomei Poncams Type B
260 Degree and 9.15mm Lift
RB26DETT
R32 or R33 GTR
Pictures:
Item:
TOMEI Complete Gasket Set.
1.8mm, 88.0mm Bore
incl: metal head gasket, metal intake manifold gasket, metal exhaust manifold,
metal throttle gaskets, oil gallery orifice.
Condition:
BRAND NEW - Sealed Packet
Price:
$500 + Postage and Handling
$450 ONO!
Pics:
  • Like 1
Price Change
Tomei Expreme Manifold - $1000 Delivered
Tomei Expreme Dump Pipes - $825 Delivered
Tomei Poncams - $850 + Postage
Tomei Gasket - $450 + Postage
Tomei Cam Gears - $430 including express post Australia wide.
http://www.skylinesaustralia.com/forums/topic/369701-brand-new-tomei-inex-cam-gears-pulley-rb-202526/page__gopid__5896580#entry5896580
please read forum rules, no excessive bumping.
thanks.
No worries. Noted.
im interested in the pon cams and extreme dumps, are the dumps a direct fit for r32 (small oxygen sensor) without modification?
Scott
Have sent you a PM :)
BUMP.
Can work something out for a few items :)
CAM GEARS $400!
BUMP
Will be in Sydney next week at the WTAC.
Will require a deposit before I bring something down though.
Cheers
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
