I had this kit for sale about 12 months ago and a friend grabbed it off me for his R32. The direction of his build has changed and no longer will be using it....so back up for sale.
Firstly some pics of the turbo...
Here is the pick of the 55,000km old Greddy manifold
A close of of the two minor repairs i have done to the manifold over the years...
Dump and "Stuff" that the kit comes with...
The below dyno is on my std RB20, std inlet and cams, head etc. Unopened engine. This was a track tune so there is another 10-15rwkws in it of you have a built motor, an RB25 that can spin it easier or you are only driving on the street so never stress the engine with high heat and loads like you get at the track
The manifold and gate came off my car when i replaced it with a 6boost manifold. I was expecting improvements in reponse and power with the 6boost but in reality the Greddy manifold appears to have offered slightly better performance. It does have small hairline crack on one of the hard to access welds, it has been this way for a while and never got worse or affected performance or was audible.
Regarding the turbo, I purchased it off yahoo about 18 months ago. To the best of my knowledge it runs no problem, but I personally have not run it. I purcahsed it as it is an L2 version of the TD06 and I currently run a plain TD06 version. People claim the L2 is more responsive but I never bothered to find out. The plan was to have the turbo rebuilt with a ball bearing core to see if it offered an improvement in performance over my current setup...but after the 6boost manifold, plazmaman plenum install all of which cost me money and for the resultant loss in performance....i cant be stuffed with more experimenting,
So all up for sale, asking $1850. Kit is currently at friends place in Brisbane, can post to metro major cities for about $60-80
https://www.sau.com.au/forums/topic/368641-td06l2-20g-setup-for-rbs/
For $500ono I will do the manifold, gate, dump pipe and oil lines for anyone wanting to run off and buy something like this for new.
http://www.ebay.com.au/itm/Turbocharger-Kinugawa-T67-25G-Trust-3-Bolt-8cm-Housing-/280694746061?pt=AU_Car_Parts_Accessories&hash=item415ab5ebcd
For results with the above ebay turbo...
http://www.skylinesaustralia.com/forums/topic/345095-another-r32-money-pit/page__st__20
Makes for a bargain 320rwkws turbo package. Seems to work well on an RB25, would not relaly hit full boost to 5,000rpm on an RB20 but would make 290-300rwkws
Well the TD06-20G in 3rd and 4th gear is hitting 18psi wel before 4,200rpm. On an RB24 it would be better but still not really getting up and going before 4,500rpm. All RBs only boogie after 4,500rpm, irrespective of what turbos are doing before hand. (IMO)
The T67 is a popular RB24 turbo. Just about all the RB24s you see coming our of Japan have T67s strapped to them so that suggests they are a resonably well proven recipe
  • 2 months later...
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
