I had this kit for sale about 12 months ago and a friend grabbed it off me for his R32. The direction of his build has changed and no longer will be using it....so back up for sale.
Firstly some pics of the turbo...
Here is the pick of the 55,000km old Greddy manifold
A close of of the two minor repairs i have done to the manifold over the years...
Dump and "Stuff" that the kit comes with...
The below dyno is on my std RB20, std inlet and cams, head etc. Unopened engine. This was a track tune so there is another 10-15rwkws in it of you have a built motor, an RB25 that can spin it easier or you are only driving on the street so never stress the engine with high heat and loads like you get at the track
The manifold and gate came off my car when i replaced it with a 6boost manifold. I was expecting improvements in reponse and power with the 6boost but in reality the Greddy manifold appears to have offered slightly better performance. It does have small hairline crack on one of the hard to access welds, it has been this way for a while and never got worse or affected performance or was audible.
Regarding the turbo, I purchased it off yahoo about 18 months ago. To the best of my knowledge it runs no problem, but I personally have not run it. I purcahsed it as it is an L2 version of the TD06 and I currently run a plain TD06 version. People claim the L2 is more responsive but I never bothered to find out. The plan was to have the turbo rebuilt with a ball bearing core to see if it offered an improvement in performance over my current setup...but after the 6boost manifold, plazmaman plenum install all of which cost me money and for the resultant loss in performance....i cant be stuffed with more experimenting,
So all up for sale, asking $1850. Kit is currently at friends place in Brisbane, can post to metro major cities for about $60-80
https://www.sau.com.au/forums/topic/368641-td06l2-20g-setup-for-rbs/
For $500ono I will do the manifold, gate, dump pipe and oil lines for anyone wanting to run off and buy something like this for new.
http://www.ebay.com.au/itm/Turbocharger-Kinugawa-T67-25G-Trust-3-Bolt-8cm-Housing-/280694746061?pt=AU_Car_Parts_Accessories&hash=item415ab5ebcd
For results with the above ebay turbo...
http://www.skylinesaustralia.com/forums/topic/345095-another-r32-money-pit/page__st__20
Makes for a bargain 320rwkws turbo package. Seems to work well on an RB25, would not relaly hit full boost to 5,000rpm on an RB20 but would make 290-300rwkws
Well the TD06-20G in 3rd and 4th gear is hitting 18psi wel before 4,200rpm. On an RB24 it would be better but still not really getting up and going before 4,500rpm. All RBs only boogie after 4,500rpm, irrespective of what turbos are doing before hand. (IMO)
The T67 is a popular RB24 turbo. Just about all the RB24s you see coming our of Japan have T67s strapped to them so that suggests they are a resonably well proven recipe
  • 2 months later...
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
