all exterior parts(white immaculate condition)
18" rims with tyres 235 front 265 rear
motec m800
rb25det with forged pistons and rods, cams, cam gears, stainless top end, strengthened crank (less than 30,000kms since rebuild)
5sp manual gearbox
lsd rear diff
nissan 4 pot front and 2pot rear brakes (EBC green stuff pads, dba 4000 rotors less than 2000kms old)
rear axle shafts
lightened and balanced tailshaft
garrett gt35r turbo
k&n filter
2x front facing plenum
80mm throttle body
stock throttle body
2x top mount exhaust manifolds
48mm turbosmart progate wastegate
turbosmart veeport bov
hks ssqv bov
300kph nismo cluster
880cc denso injectors
bosch high volume fuel pump
high flow custom injector rail
splitfire coils
polished rocker covers with breathers & catch can
turbo back 3" exhaust
bilstein shocks
king spring SL springs
all whtieline bushes
radiator
power steering pump
a/c compressor
a/c condenser
alternator
m spec spoiler
vented bonnet
2x short shifters
tail lights
nismo side indicators
all interior parts
black gear/handbrake boot with white stitching
all original windows
2x defi bf boost and oil temp with sensors
greddy pillar dual gauge pod
AND MUCH MORE JUST MESSAGE ME FOR ANY PARTS/BOLTS ALL PARTS ON VEHICLE ARE AVAILABLE
0401439396
vehicle made 480rwhp and was all in good condition when removed
https://www.sau.com.au/forums/topic/369074-wrecking-r33/
Hey man I'm interested in your center console and gear surround (including gear and handbrake boots).
how much? What's your location? Will u post to Somerville 3912?
https://www.sau.com.au/forums/topic/369074-wrecking-r33/#findComment-5884155
  • 5 weeks later...
Hey can you pm me details of:
Dump, front and cat pipes, the size, if it's stainless, and if it's high flow cat.
Hks Ssqv, how old it is, what's involved in fitting it to a gtt
KN filter is it pod?? How old is it? What material is it??
18 inch wheels, pics?
Can you also include price on all of them??
https://www.sau.com.au/forums/topic/369074-wrecking-r33/#findComment-5957815
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
