Watch out!!!!!
Just a bit of a warning guys.
Last night leaving work I hit and launched off a large piece of that 3/4 concrete kerbing that had been moved onto the road. I'm not sure how it got there but I know this area very well as I drive home this way every time I drive to work. So this is just a small warning just because you think you know a piece of road doesnt mean that its going to be the same every time you drive along it.
I know this is pretty basic stuff but I thought that too before last night.
In regards to the GTR she looks ok in the light of day but I'm just about to go and have a good look underneath. Rims are fine due to the fact I hit the kerbing pretty much square on, nothing has sprung a leak from the hit. But at the very least I'm going to need a bloody good wheel alignment.
Cheers.
https://www.sau.com.au/forums/topic/3691-watch-out/
SO true Rhino,
I remember pulling into my road off Warnbro Snd Ave. (Troy would know where this is)
And being a corner, I couldnt see the BRICK i hit square-on. Needed a wheel alignment and balance after that... not to mention a new pair of underwear....
:confused:
https://www.sau.com.au/forums/topic/3691-watch-out/#findComment-60573
This was the carpark at Riverton forum out the front of the Commonwealth ATM.
Well just had a really good look around, got the car up on stands, removed the plastic shroud under the front of the car etc.
All the rims are exactly the same as before the mishap, so thats a relief :D
It seems a powersteering hose has had a slow leak but I'm not sure if it is an old or new one as there aren't any spot marks on the driveway. I figure it's just a buildup over the years.
All the suspension looks fine shocks,springs, castor rods, bushes etc.
BUT!!.......
The car now pulls to the left slightly so a wheel alignment and fiddle with my suspension geometry is on the cards. I'll get Wilkinson sus. to have a fiddle sometime before the MC day.
So to conclude everything seems to be A-OK but christ I had a bad nights sleep worrying about stuff:confused:
Cheers.
https://www.sau.com.au/forums/topic/3691-watch-out/#findComment-60598
Well,
The suspension is totally fine as are the two right rims but it turns out the two left ones are slightly buckled. So new rims here I come...anyone know someone with some R33 GTR rims??
Or anyone who wants to buy the 2 good rims or all 4??, will throw in the GGrids they were wearing when the car came in from japan.
Cheers.
https://www.sau.com.au/forums/topic/3691-watch-out/#findComment-63086
Are you sure it's the power steering leaking and not one of the suspension bushes broken after the knock?
I had this and found that the front tie rod bushes are silicon filled and leak with age and the odd kerb.
Just look under the front of the car with the splash tray removed and you will see them as the suspension part that is towards the front the most ......
https://www.sau.com.au/forums/topic/3691-watch-out/#findComment-63507
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
