Hi, as the title says im installing a boost guage in the GTR
everything is all sorted but i cant get the farkin boost pressure pipe thing (that hooks up to the back of the guage) from the engine bay to the interior....
any body got any tips on where to find a firewall to squeeze the tube through??
I got told there is one at the top left of the engine bay but I tried forever and couldnt get anything through
any tips/suggestions/prior experiences would be greatly appreciated.
Cheers
U
https://www.sau.com.au/forums/topic/369316-help-boost-guage-install-33-gtr/
There's a few good guides on here on installing boost gauges, i ran mine through the firewall just to the right above the accelerator pedal had to cut a little hole through the rubber gromet carefully and came up back through the engine bay just near the little black box i think the stock boost gauge hose runs into was fairly easy was a hassle grabbing the hose though used some long nose pliers
http://www.skylinesaustralia.com/forums/topic/102049-boost-gauge-and-pillar-pods/page__hl__pillar+gauge+install
i used this guide worked well has pics :)
Edited by nismo07
i c... thanks for that... im not too sure if GTS-T and GTRs have the same setup... i remember it was really easy on my old GTS-T... on the GTR is an absolute mission for some reason
ill look around the accelerator on the weekend but im pretty sure its the same one i tried today
cheers
cheers
Yea im not sure either wouldn't see why they wouldn't be though :wacko: took me ages to find the rubber grommet though was really buried ...
'Would like to add that the R33 GTR's don't have that hole in the firewall next to the stereo. Instead you'll have to cut open the large rubber grommet where the loom travels through, which is just to the right of the accelerator cable behind the insulating stuff.'
looks like i have some cutting to do on the weekend
thanks!
jesus dont cut anything grab a bloody piece of long wire or electrical line tape the vac line to the hard wire and poke it thru the gromet thus making a clean hole not butchering crap jesus
just wanted to add one more " JESUS " :D
Edited by v8tzr
agreed. there is no need to cut any grommet anywhere on the firewall in any model GTR just to get a boost hose through there. I can get plenty of sensor wires, boost hoses etc throuhg the various grommets without cutting anything.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
