Hey guys got alot of standard R32/33 GTR parts for sale
Aircon Fan $50
Air con Condensor $100
Air con pump $100
Air con pipes from firewall to pump/condensor $50
Exhaust Front pipes $75
Turbo Dump pipes x2 $50
Coil packs $100
Flywheel $75
Clutch $50
Short Shiter $100
Camshafts $100
Cam gears $30
Crankshaft R33 GTR $150
Oil pump R33 GTR $100
Standard Computer ECU R33 GTR $75
Steering wheel with airbag $250
These parts are all STANDARD except the short shifter and are all in perfect working order.
Contact Christian on 0423756123
https://www.sau.com.au/forums/topic/369368-gtr-engine-parts-fro-sale/
what brand short shifter? does it come with everything including the rubber dust cover?
Not sure what brand but its fairly new, works perftect and comes with everything to put it in. No does not come with dust cover. Should b on your car already
Hi, How much to post the a/c compressor to brisbane.
Cheers
Clynton
Hi mate, ill do it for $130 delivered, contact me on 0423756123 and we can organize it if you want it, cheers
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
