  • Replies 58
Well ..... mine was my mates WRX impressa evoII.... scared the shit outa me ....hehe after that all i caould vision was a turbo import .. so i got me a nice 97 180sx white with yellow interior .....but got hit up the ass at 100klm pu tme in hospital then after all that i bought another 180 wich i own still and love it ....!
first time tasting the sweet motion of boost was in my mates r33 gtr i was 15 at the time and he was a 40yr older.. I wonder who is to blame for my passion of the skyline. but the car was to expensive to buy, after some research in came some of the more budgetable skylines... :D gts25t and so on.. first time actually driving on boost.. VL turbo... nothing better then driving wit your heart pounding...
  • 3 weeks later...
My VERY first taste of boost was in my dads porsche... however i was WAY too young to remember it lol and because i came he had to sell it... typical.
The first time i had ever ridden in and driven a Turbo car was when i was 16yo and my dad had a Twin Turbo Mitsi GTO which was modified. OMG i instantly fell in love and became a bost junky.... until i realsed cars in australia to this caliber were still selling for 40k+ (born and raised in NZ, his car sold for 17k).
It was the car i learnt to drive in while in NZ on holiday and it had a porsche gearbox in it which was ultra smooth and short... awesome car.
I lost my virginity to a turbo silvia on 18psi grin ear to ear.
First drive was R33 GTS-T and since then have been re born that's why I'm clawing at the walls for the next 3 months till I can get mine. I'm having with drawl symptoms....... come on mate just give us another shoot of boost just a little for the road? :drooling: :nowigetit :nowigetit :boinkcar:
Mine was about 2 years ago when I was looking to import my first Skyline. My dad and I met up with the importer who was a friend of my dads. We met him at a servo on his way home and he threw us the keys to the R33 GTR V-Spec sumthing he was driving. He had just picked it up fromthe docks and it still had some type of semi slicks on it and from my memory (I knew jack all then) it had aftermarket turbs, pods, brakes etc etc. This thing was so fast is scared both me and my dad :D Never looked back since and still by far the quickest car I've driven.
had to be a skyline.... 1979 4 door something (not up with the model numbers from back then) has an L28-ET conversion, which is largely a custom build me thinks...runs ~ 22psi and OMG... zoom zoom bloody zoom zoom... scary stuff - specially with 17yr old driver - carazy man !! :headspin:
Currently ANY 32 turbo is in my sights... NA skylines nice, but turbo = even better !!
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
