  • Replies 58
Well ..... mine was my mates WRX impressa evoII.... scared the shit outa me ....hehe after that all i caould vision was a turbo import .. so i got me a nice 97 180sx white with yellow interior .....but got hit up the ass at 100klm pu tme in hospital then after all that i bought another 180 wich i own still and love it ....!
first time tasting the sweet motion of boost was in my mates r33 gtr i was 15 at the time and he was a 40yr older.. I wonder who is to blame for my passion of the skyline. but the car was to expensive to buy, after some research in came some of the more budgetable skylines... :D gts25t and so on.. first time actually driving on boost.. VL turbo... nothing better then driving wit your heart pounding...
  • 3 weeks later...
My VERY first taste of boost was in my dads porsche... however i was WAY too young to remember it lol and because i came he had to sell it... typical.
The first time i had ever ridden in and driven a Turbo car was when i was 16yo and my dad had a Twin Turbo Mitsi GTO which was modified. OMG i instantly fell in love and became a bost junky.... until i realsed cars in australia to this caliber were still selling for 40k+ (born and raised in NZ, his car sold for 17k).
It was the car i learnt to drive in while in NZ on holiday and it had a porsche gearbox in it which was ultra smooth and short... awesome car.
I lost my virginity to a turbo silvia on 18psi grin ear to ear.
First drive was R33 GTS-T and since then have been re born that's why I'm clawing at the walls for the next 3 months till I can get mine. I'm having with drawl symptoms....... come on mate just give us another shoot of boost just a little for the road? :drooling: :nowigetit :nowigetit :boinkcar:
Mine was about 2 years ago when I was looking to import my first Skyline. My dad and I met up with the importer who was a friend of my dads. We met him at a servo on his way home and he threw us the keys to the R33 GTR V-Spec sumthing he was driving. He had just picked it up fromthe docks and it still had some type of semi slicks on it and from my memory (I knew jack all then) it had aftermarket turbs, pods, brakes etc etc. This thing was so fast is scared both me and my dad :D Never looked back since and still by far the quickest car I've driven.
had to be a skyline.... 1979 4 door something (not up with the model numbers from back then) has an L28-ET conversion, which is largely a custom build me thinks...runs ~ 22psi and OMG... zoom zoom bloody zoom zoom... scary stuff - specially with 17yr old driver - carazy man !! :headspin:
Currently ANY 32 turbo is in my sights... NA skylines nice, but turbo = even better !!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
