I have a chance to trade something for this AEM FIC ( http://www.aemelectronics.com/engine-management-systems-9/fuel-ignition-controller-f-ic-12/ ). Has anyone used one of these? I know its not a ems, but I have been reading good things about it. I am wondering how they do on the rb's.
https://www.sau.com.au/forums/topic/369385-any-work-with-one-of-these/
there are so many cheap good engine management systems available for all RB engines that there's no way I'd bother with a signal bender/piggyback these days. if buget is an issue there are plenty of second hand gear out there which is fine.
I will be upgrading later, I just need something to get the car going.
My setup is as follows:
rb20det
redtop block with a silvertop head
neo turbine
440cc supra injectors
front facing inlet manifold
small port job on intake and exhaust ports
3in turbo back catless
walbro 255l fuel pump
adjustable fuel pressure regulator
Bend the signal AFTER the ECU?
What?
After the ECU has already read incorrect information from modified parts, how exactly is that going to be fixed.
A signal bender device cannot fix a car running poorly POST ECU if its being told to go to various map load areas?
Well I just did a whole long reply, as I was reading more up on this thing. Looks like it does both. In order to adjust the timing (retard only) it intercepts the cas signal to the ecu, but to adjust the fuel it intercepts the injector signals from the ecu. It also taps into, but does not intercept, the tps and o2. It also has a built on map sensor that you can use to tune with.
I am kinda looking for reworld reviews. I dont like only going by company pushed reviews. I could just get CarlH from nico to do a rom chip/tune, but the only reason I am looking into this is cause its brand new and free pretty much to me. I guess if I had to pay the money I would just get the rom tune.
thanx for the feedback.
If its free then why not, install it and take it to a tuner, let them tune it and see what they think of it, the real test is in the results, or you could just go talk to who ever your getting to tune it and see what they think of it, im sure most tuners have seen all the cheap and nasty shyte around these days and will be able to tell you if its cheap or nasty!
YES, I use the Aem Fic-8 piggyback
I have a remapped ecu and use the Fic-8 to finetune the fuelling (larger injectors).
So you need both?
remap for the larger injectors
and this AEM thing to further bend the signal after-the-fact?
Why couldn't the remap sort this out?
Im confused :blink:
You dont need both, at least thats what aem says. I do think it would work better if the ecu it was piggy backing was tuned.
The one I might get is the fic-6. I think the 6 only misses 4-5 things that the 8 has.
Edited by Driftnuttz
no Ash you dont need both. I wasnt exactly happy with the tuned Rom ecu remap, was running quite rich & felt "doughy". Remap was a mail-order from Toshi, so obviously a bit of a hit & miss affair being a generic guesstimate tune.
I added in the Fic-8 to replace a stolen set of SAFC & SITC piggybacks, and wired up the S15 450cc injectors to run directly off it, ended up with a great result.
Power went from 200rwkw to 230awkw with the Aem Fic-8 tune, with a tired bottom end.
Bottom end is being rebuilt currently, in due time will retune to hopefully around 250awkw.
    • I should. But it already uses too much fuel for a daily. You might note my recco for engine chnages are almost exclusively to people who have it as a weekender/summer car. I don't even have room to keep the spares for this one, let alone another car.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
