I bought an R33 gtst series 1 about a month ago and i would like to remove the "defect me" signs that are currently mounted in an A pillar gauge pod.
Two Blitz gauges, boost and oil pressure.
There doesn't seem to be an easy answer other than, just rip them out and leave them out.
I didnt buy this car with the intention of spending alot of money on it and turning it into my pride and joy, i might get an R34 to fill that role later on, so getting something custom made to fit down low in the dash below the headunit or where the ash tray currently sits might be going a bit far.
I havent seen anything online for the R33.
If you have gauges , where did you put them ?
I've got my tempreture gauge under the dash next to the steering wheel. It came like that and I might move it to where the ashtray sits now. Only question is, where arm I going to put my spare change
grab a stubby cooler and put it in the console, great for spare change.
got my boost gauge mount on the shroud behind the steering wheel so it covers the stock one in the dash i moved it there as it was covering the oil pressure gaufe took me 2 seconds and looks really good
Ive already got one in there holding my sunnies. I was thinking about some how relocating it to the glovebox. Could be kinda cool
got my boost gauge mount on the shroud behind the steering wheel so it covers the stock one in the dash i moved it there as it was covering the oil pressure gauge took me 2 seconds and looks really good
That's not a bad idea, I'll have a look at that.
yeah it gives a whole fast n furious feel to it lol
na i was actually watchin some drift vids on u tube n saw it and thought it looked good but as it sits low in the car it cant be seen from out side by h/w patrols goin past me so it looks like the car is untouched ; D
Same. Mine doesn't block anything, it sits just off to the right
yeah mine was just off to the right but on a crap little stand thingy
so hacked that off and stuck just the gauge itself there
now it sits heaps lower n dont block anything
I made a little facial plate from black MDF board to cover the ash tray hole, used a hole saw on it and slid the boost gauge in. Its low, no extra holes in the car or needing of those ugly silver holder cups! ;)
Ive been thinking, I could probably get another fascia for about $50 if i stuff it up, so i will have a look at where i can fit the gauges in the fascia itself.
By removing the clock for example, will have a look around and see what i come up with.
If not then mounted to the steering column will be my second choice i think.
Any pics you guys have would be good to see aswell
ill get a pic of my gauge mounted under my dash next to the steering wheel, just to show you its not very pretty. if u have the time put it somewhere nice or get a nice holder i rekon. unless your going for the skid/drift pig minded person minded person look. or if you like the raw look of it hha
Edited by drunkn snail
under the dash........ that would be be impractical and look f#*king stupid
yer it was already there when i got the car, its not too impractible, its pretty easy to see, just doesnt look "finished"
I took my gauges off the pillar today and tried them in a few different spots to see how they look.
At first i liked this one but now it just looks wierd
Out of the places i tried i think this one is probably the best, I dont love it, not by a long shot.
They will be just stuck there with double sided tape,,, bodgey as bro.
But at least they'll be a little less conspicuous.
Any of you guys reading this have the same gauges by any chance ?
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
