ok been looking through all the older threads and this turbo seems to be the best option for my 33, i dont wanna touch the internals, but will get injectors/pump, atm i got powerfc, ebc, fmic, high flow panel filter and full exhaust (3" and 3.5" catback HKS and 3" cat)
questions is, what sort RPM does this turbo come on boost and what sorta power can i get from it on stock internals whilst keeping it nice n safe because its a daily driver
also i got an exedy/daiken heavy duty organic single plate clutch, will that hold up with the new power ? if not what clutch am i looking at or should i wait till i kill this one ?
cheers
https://www.sau.com.au/forums/topic/36977-2835-rb25det/
  • 3 weeks later...
cheers
There is an interesting Garrett BB turbo on the ATP Turbo site (US) . It uses the GT30 (55x60) 84 trim turbine and a GT series 53.1x71.1 compressor in a .50 AR TO4E comp cover . They're calling it the "GT3071R" . Supposed to be good for 400 wheel HP and spools 1,000 rpm sooner than a GT30R . It should be ideal for a high compresson motor such as the RB25DET and can be had with T3 flange housings in 61 , 82 , and 1.06 AR ratios . HKS also do housing with .73 , .87 etc .
ATP even do a 63 and I think an 82 AR integrally gated housing to make it a "direct fit" . I have not been able to get a part number for it yet but in time . Chow for now ...
https://www.sau.com.au/forums/topic/36977-2835-rb25det/#findComment-770900
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
