When I first bought my car it was missing the little shims between the pads and the brake caliper which are designed to minimize noise. And it used to work, it was such a change. Yesterday I took the car for a spirited drive, only about 5 mins down some nice roads and immediately my brakes started screaming. It was ear piercing. It killed any bit of driving enthusiasm I had in me as I too noticed immediate brake fade and they just felt like they weren't going to do much after that. Normally they stop fine in traffic and on the roads. I planned to go to the next cruise which involved curvy roads but there is no way in shit stick that I am taking the car there in this condition. My cousin was in his car and he was like the brakes are worn out... They have about 3000km on them and they are no where near worn. Its not the screech of the indicator hitting the rotor, its a squeal of a million cats dying at once.
Anyway my car is equipped with the standard R33 brake calipers, DBA slotted rotors and QFM HPX pads.
I'm nearly f**king tempted to rip of these brakes and rotors and just buy a new front set but that would set me back almost 2k so that is a dream for now. Anyone have any ideas? And to add note, the rotors were not machined when coming from my old pads(endless brakepads). Could this be the dinosaur dick killing my brakes?
https://www.sau.com.au/forums/topic/369919-why-are-my-brakes-screaming-for/
  • Replies 43
That was going to be my guess even before I read it.
Most modern pad compounds (since asbestos was banned) are VERY reliant on having their material on the rotor for them to work properly, and we know this to be particularly true of the QFM pads.
As has been said, take the pads out and give them a light rub on some concrete, and give the rotors a light machine and you should be fine. The HPX is definitely not known to be a noisy pad.
That said, HPX we've phased out in favor of a better performance street pad. It's a European performance pad called Remsa, which is rated to 650 degrees (versus 550 for the HPX). Also the Remsa come with noise reducing features such as a relief groove and shamfers in the pad material, as well as a soft backing shim, all of which the HPX do not come with. We've been supplying Remsa to high performance street road cars like Porsche and Ferrari for many years, but the pricing has now become such that we're now able to expand it to most road cars.
I will be checking the thickness of my rotors tomorrow and if they are good for another light machine I will get that done. Otherwise I will be getting rid of my rotors and may upgrade my pads too. Those Remsa pads sound tasty!
I just got the rotors machined, I gave the pads quick and thorough rub on sand paper to remove the mirror surface. I put everything back together and took it for a drive(all shims and what not in place etc) and started bedding them in. After the third bed in step they were screaming. A few more, my ears were done and I was really embarassed to drive it around anymore. Why are they doing this? New surface on the rotors and they are still screaming...
Yep I have the same problem, tried lots of different things...
Ive even tried anti squeal spray, works a little, but Im not one for using that kinda stuff usually...
Band aid fixes, I try avoid them. This is the only car we have that squeals. The rotors are off my old car and that car had endless brake pads. They were the best. No fading and no squealing.
Hi.
If it was me i would replace the pads with a set of standard 400c pads should fix the problem. Sounds as if your pads are too hard or the pad mix is incorrect.
A little tip if you use your car only on the street a harder pad takes longer to heat up therefore is not as efficient as a standard pad.
Just quickly, you need alot more than a few quick stops for pads to be bed in properly. Bed in is about transferring an even layer of pad material to the rotors, and nothing to do with putting excessive heat through the pads, or burning off resin etc.. This can take up to a couple of hundred k's. The noise should go away once you've put a few k's on the pads.
That said, what sort of shims did you refit to the pads? If it's the standard metal type shims, they generally cause more noise they they save, and we rarely recommend fitting them to QFM pads. The only two types of shims that I would recommend would be the soft stuck on shims that EBC/Remsa/TRW etc come with standard, or a soft wrapped metal reusable one, like the Project Mu ones:
The only other thing I could suggest is applying a small 5mm chamfer on the leading edge of the pads, similar to what alot of OE pads some with standard.
Ive had the same problem with my R34 ive tried two different brakes, the rotors machined and used crc anti squeal goo but the screeching is still there. i am missing the brake shims though but i cant find a store which sells them any ideas?
The brake shims made a HUGE difference when I was running my old brake pads. But running them with these HPX pads doesn't do anything. Its a little better but the screeching is deafening.
Nissan will sell you the set for about $200 which is a f**king rip off. Just buy another set of brakes which INCLUDES a set of shims. Remesa pads above come with a set as do a few others.
The temptation just to buy new calipers, rotors and pads set is kicking in. Ive spent about $600 on brake gear so far and need to spend about $600 more to get new rotors and pads. That is 1200 which I could have put towards a Ksport set or a little more for a wilwood set. I'm gonna give my pads another few hundred km to set in on the machined rotors, if no luck ill be going from there.
Ask Greg(gsrally guy posting in here) if he sells the shims alone. He suggests the spongy/foamy shims rather than metal. The reason we get noise is because of vibrations passed through the pad and rotor. Metal on metal won't really do shit to eliminate this noise...
Yep, those Project Mu shims are brilliant, in fact, Sarge, if your brake don't quieten down in the next couple of hundred k's, let me know and I'll send you a set of them as a free trial.
Normal price on them, to suit both Brembo and Sumitomo, is $65 for the front set, and $55 for the rear set.
Unfortunately noise is a constant bugbear with opposed piston calipers...
Sounds like these shims may be the go for my QFM pads as well... I never had squealing issues like this before, I know its not the pads fault because Ive run them before with no problems...
the only thing I can put it down too is shim setup...
i 100% agree!
ive been using the project mu shims and they have helped alot with my brakes
Are you referring to the Nissan Brake shim kit? I bought one and it cost me like $22 from the local dealer, and comes with the copper grease. Never had an issue with any squealing or noisy brakes. Comes with all the items below from memory except items 6 & 7
WTF! They were $220 from Nissan up the road from me. Where did you get them?
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
