Ive been looking around at getting a POD filter for my RB25DE and thought id nail two birds with one stone. First of all what size am I meant to be looking for I haven't seen a straight answer to that yet. Also everywhere I look says they are for race purposes only? surely this isn't right and im looking in the wrong places!
Any help for either question would be great! cheers guys, thanks in advance!!! =]
https://www.sau.com.au/forums/topic/370580-pod-filters/
Hey mate,
Firstly let me suggest you buy a Decent Panel filter Like a KnN or a BLITZ they will be legal and basically do the same job.
I bet all your friends have said dude get this and that, it will make it go better, WRONG. In Reality a POD filter will do nothing but suck hotter Air Into the engine, unless you also invest in a COLD-AIR intake then It might do something, but it will still Be very minimal. You will be much better off leaving the stock air box and funnel, the engineering of it its awesome!. Cold air straight from the front bar, Unless you want a FULLY SICK waste of $30 bucks, and a defect notice. Yes they are illegal unless covered.
Perhaps a change of spark plugs instead of wasting your money.
To answer your question, Use the search tool. This has been covered before, or just maybe buy the right size adaptor.
JUZ.
https://www.sau.com.au/forums/topic/370580-pod-filters/#findComment-5907034
Agree with Juz.
Considering you're not driving a turbo, investment in a pod filter will deliver very marginal returns in terms of performance. The best investment for you would be a high flow panel filter - K&N make good filters and are guaranteed for life, service needed every 30,000kms. I use a high flow K&N panel filter in my EVO 8 MR and wouldn't convert to a pod filter unless I purchased a cold air box or relocated the pod to the front bar.
Cheers
Shanil
https://www.sau.com.au/forums/topic/370580-pod-filters/#findComment-5907079
Pod filter = useless mod, if your stock IC piping will allow the use of the stock air box use it, I do recommend modifying it so it has a cold air intake and a larger route for the in coming air, Google "modify standard air box" and "cold air intake' for some easy DIY projects.
https://www.sau.com.au/forums/topic/370580-pod-filters/#findComment-5907089
I had to make this decision a few weeks ago firstly panel and pod are nearly identical in performance, so I ende up going the pod filter. Why you ask?
1. I built a heat shield
2. I modified the stock CAI so it delivered cold air to the pod
3. I liked the difference in sound when you put the pedal down
4. Fuel efficiency has been improved either due to hot air being sucked in an therefore leaner fuel has been used OR more power has been delivered because of the same amount of fuel or less therefore less fuel has been used
5. It was just something to do in my holidays
Panel filter will do the same thing, get a high flow one, the stock airbox and snorkel is excellent!
I know there has been many topics on pod vs panel but in the end I believe a pod with a good CAI and heat shield wins if you can invest time and money.
https://www.sau.com.au/forums/topic/370580-pod-filters/#findComment-5907104
Haha reasonably spot on about how my mates are telling me all sorts of things! just new to the whole thing so trying to get as much information as possible before going out and wasting money away. Cheers for the links im hitting them up now, always keen to get into DIY.
You also may have steered me from POD's
https://www.sau.com.au/forums/topic/370580-pod-filters/#findComment-5907129
Hey mate,
JUZ.
depends what state as to legalities of pod filter. in QLD you don't have to cover them but they have to be securely fitted with a bracket. the f**ked up thing is that the actual ruling is that an air filter is classed as being part of the fuel system. and it actually states that the air filter must be "securely fitted to the fuel system" meaning the clamp you use to fit the pod to the intake must be tight. but cops up here will still defect you if you dont have it bracketed to the chassis unless you can prove them wrong or in most cases go to court where the judge says "well officer was the air filter securely fitted to the fuel system?" to which the officer has to reply "yes" and then you win. i for one run a bracket on my pod because id rather not go to court because i was right lol.
Edited by Blueone
https://www.sau.com.au/forums/topic/370580-pod-filters/#findComment-5907183
Ha well then is there a difference between brands? or i suppose my question is how big is the difference between brands? like will you get more power or better sound from one? is it personal preference? and if there isnt much difference whats to stop me from getting a cheap ass one? :P
https://www.sau.com.au/forums/topic/370580-pod-filters/#findComment-5907292
Well when your 15 dollar pod disintegrates and ends up inside Your engine... lol
i choose HKS because HKS is good and the sound is the best in my opinion.
https://www.sau.com.au/forums/topic/370580-pod-filters/#findComment-5907348
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
